75,000 Mile "Checkover"?
Old Jan 24, 2007 | 05:21 PM
atc250r's Avatar
I haven't been driving the truck much the past couple of years and now I'm working a new job that requires 100 miles round trip everday in it I want to give it a once over. I've got a few bucks saved and want to take care of some of the common problems before they "take care" of me. From searching around here the last couple of days here's a quick list of what seem to be common problems I haven't addressed/things I should check:
- Check fuel pressure for possible lift pump problems (I thought these only acted up on 24V'ers but I've learned otherwise) and possbily just replace pump
- Replace Overflow Valve
- Clean Fuel Pre-Filter
I've already done the 5th gear nut and changed the fuel filter as well as all the fluids. Also, the KDP is pinned, all the front end parts are good. I'm just throwing this out there to see if anyone has something that I've completely overlooked (which I'm sure I have).
John
Old Jan 24, 2007 | 07:37 PM
NHRedneck's Avatar
Cool
change your driveline fluids to synthetics if ya feel like it, P/S fluid service and check all you batt connections for corrosion and if you have any "bad" wires have them replaced
Old Jan 25, 2007 | 08:11 PM
atc250r's Avatar
Thanks. I'll add the PS drain and fill to my list. I already put Redline fluids in all the driveline parts. Anybody else? I figure this list would come in handy for others looking for a comprehensive list of things to look out for.
John
kenni
62
Mar 11, 2012 08:46 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Commatoze
Aug 19, 2004 04:00 PM
spots
May 28, 2003 10:44 PM
Shovelhead
Jan 6, 2003 02:31 PM
