6spd Possible???
Old May 13, 2008 | 11:13 AM
Big Red 97''s Avatar
6spd Possible???
If possible how hard would it be to put a 6 spd tranny behind my 12v?
Old May 13, 2008 | 04:20 PM
renopker's Avatar
why dont you do a search on that ??
Old May 13, 2008 | 08:43 PM
gorms's Avatar
I was a stones throw from getting a 5 speed and swapping out the auto because of a bad torque converter, but I got a good deal on a new converter instead.
It's not easy, but is do-able. A donor truck is ideal, because finding the misc. pieces like new pedal assembly, flywheel housing/ bell housing adapter, driveshaft (6spd trans is shorter than auto) and new input/main shaft on transfer case for 4wd can get time consuming and expensive. Realistic costs will be at least $3k (closer to $5k from my experience) even if you get some deals, but like I said, do-able.
Old May 16, 2008 | 11:54 AM
Troutstrannysvc's Avatar
Yes it is do-able but you would be further again swapping in a 5 speed. You will not be saving any fuel w/ a 6spd compared to a 5spd if that is what you're looking for.
The ratio from 6th gear in the NV5600 and 5th gear in the NV4500 is only .2-.3 of a difference. The difference is the rowing of gears.
All you really need is a pedal assembly, slave/master cylinder, Clutch, flywheel, input on your transfer case, transmission, bellhousing, lengthen/shorten drive-shafts...
And if you go w/ the 13" for the NV4500 (Which uses the NV5600 flywheel), or the NV5600 and clutch assembly you will need the starter spacer.
-Jared
Old May 16, 2008 | 12:47 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
-Jared
If you tow at all a 12v married to a 6spd is a perfect combo. it eliminates teh annoying 3rd gear blues that the nv4500 suffers from.
get a 98+ manual tranny crossmember it has the holes for a 5spd and a 6spd.
you do not need a 6 speed flywheel a 5spd flywheel works but 6spd flywheels are cheap now a days when you buy a whoel clutch kit ect. the starter spacer is $20 from cummins. you'll also need the later style screw on shifter vs the early nv4500 pop on style. the clutch fork and throwout bearing ar e the same on both the nv4500 and 5600.
Bar none best conversion i ever diod yo my old 12v before i sold it, the nv4500 used to last about 150k miles before an OD would fall off or the input would fracture. my nv5600 went to 280k miles before a syncro ot two started scratching in second. I sold the truck with 450k on it and the tranny was rebuilt by the next owner.
i hated 3rd gear in my 12v on the nv4500 that 6spd with the 3/4 split 4th gear was perfect for maintaining speed on long steep grades with a heavy load and not dropping below 50-55 mph third gear used to tach my poor motor out.
do it its not a hard conversion at all. I might have missed it but are you an auto or 5spd already? 5spd already its a super easy conversion, auto not much more to it. different flywheel bolts add a hydraulic clutch assembly and hole in you carpet along with new pedals and you are good to go.
FYI my old 12v started life as a auto. then a 5spd then a 6spd where it stayed . if you are drag racing or in town a 5spd is king but towing 6spd offers better flexibility
Old May 16, 2008 | 08:09 PM
renopker's Avatar
I say go with a g56 set up forget the nv5600
Old Nov 21, 2009 | 08:55 AM
SKATERHAULER's Avatar
What year did the 6 speed start ?
Old Nov 21, 2009 | 02:57 PM
Tate's Avatar
Started in '99.
Old Nov 21, 2009 | 03:21 PM
illEatUrDuramax's Avatar
how much do the g56 usually run? because im wanting to do a 6spd swap too.
Old Nov 21, 2009 | 03:38 PM
traverler48's Avatar
Just what would be involved in changing from the 5 speed to the 6 speed? My truck is a 95 with 93K never had any problems with the 5 speed but the 5th gear nut gives me some concern. I carry a new nut with set screw with me at all times. I am pulling about 9k and pull on the Natchez Trace a lot and the speed limit is 50 mph I either have to drop to a lower gear or do 60 if I ever have a problem with the nv4500 that may be better option if the price difference was not alot. I never thought about upgrading to a dif trans.
Old Nov 21, 2009 | 04:52 PM
rich's Avatar
you dont want the g56 with 4:10 gears
Old Nov 21, 2009 | 06:44 PM
If I found a 99 V-10 with six speed would that swap right in my 95 12 v ?
Old Nov 22, 2009 | 09:59 AM
rich's Avatar
yea it should it should most everything would work not sure about the driveshafts tho
westport
Nov 24, 2005 01:43 AM
norsk
Jul 19, 2005 08:26 PM
latitud_rt
Mar 11, 2003 04:51 PM
xzlram
Nov 10, 2002 08:28 PM
chuck3
Oct 15, 2002 01:17 PM
