6 speed manual swap
Old Mar 11, 2015 | 01:59 PM
flyingd's Avatar
6 speed manual swap
If I decide to put a 6 speed manual in my auto truck, what years should I look at and what years to stay away from. Also, will I have to get a new PCM because I am going from auto to manual. Any other "special" items that I would have to replace?
Thanks
Old Mar 11, 2015 | 09:01 PM
gorms's Avatar
I think 05 or 06 and later came with the G56, alum case Mercedes trans. 02 up to then carried the NV5600, heavy sob with cast iron case. Do you research to see which is right for you. 5600 would probably go in easier with a donor truck. Either needs crossmember replacement, different than auto or NV4500 mount. Transfer case needs at minimum input shaft swapped regardless of the manual in front of it.
If you can live with a check engine light you won't need to do a thing with the PCM, mine burnt out after about 5 years finally.
fpr01
13
Sep 21, 2008 11:31 AM
Burkert
21
Nov 26, 2007 07:09 PM
bolkowdude
Oct 5, 2007 10:47 AM
MossyOakGlock
18
Sep 21, 2007 03:42 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
