5 speed rpm/speed?
Old Jan 28, 2008 | 10:48 PM
3SmokinC's's Avatar
5 speed rpm/speed?
Hey Guys,couldn't find much about this.I was wondering what kind of road speed you guys are getting in fifth gear on the highway?I think I have the 3.55 rear end with 295/75/16 tires and at 1800-2000 rpm I was only doing about 100km/hr I think it's around 60-65 mph or so,does this seem right to you,I was expecting more speed for those revs? thanks...............Burke
Old Jan 28, 2008 | 11:48 PM
90dodge's Avatar
od speed
Well I have 4.10 gears with the 5 speed, with 245 75r16 tires and am turning 2500 RPM @70mph.
Dose any one know the finial gear ratio of the NV4500 in O/D?
Bob
Old Jan 28, 2008 | 11:49 PM
strokerace's Avatar
I run about 2000 or so at 70 mph with my 3:55's and have 265/75/16's, yours sounds like 3:55's to me, look under the hood, there should be a sticker on the underside of the hood itself that will tell you.
Old Jan 29, 2008 | 05:41 AM
12 flapper's Avatar
I know my truck has a 5 speed with 3.54 rear and I can only do 98 mph before I read line
Old Jan 29, 2008 | 07:47 AM
96_12V's Avatar
I'm at just about the same, maybe 2100 rpm for the 70mph speed. Same 265/75/16's tires. Although my speedo is off by about 4mph (probably a good safety net). Strangley, the 4-speed automatic '95 4wd I owned over six years ago would run about 1850 - 1900 at 70 mph. Was a bit odd - anyone know why?
Old Jan 29, 2008 | 07:51 AM
96_12V's Avatar
53 flapper I would guess that if it's not cracked by this point, your "53" block will probably be fine. You have really nice low mileage, but it's likely thermo-cycled enough times by now to have cracked if it was going to crack. Hope this is right!
Old Jan 29, 2008 | 09:52 AM
NMCTD's Avatar
nv4500 overdrive ratio is=.75
automatic=.69
nv5600=.73
Old Jan 29, 2008 | 10:06 AM
Ru rammin 2?'s Avatar
I have 4.10s and 285/75/16s and I run about 2500 to do 75mph, about 2000 or so at 60-65. I used to govern at about 83 mph or so and with the new gsk I racwd a 24v last night on the highway and backed out of it at around 90 mph, I think I was around 3000 or so, but my speedo is off a bit, too.
Old Jan 29, 2008 | 08:55 PM
Tate's Avatar
Have you had your speedo re-calibrated for the bigger tires? I run 110km/h at 2k rpm, with 235/85/16s, which are 31" tall.
Old Jan 29, 2008 | 10:29 PM
90dodge's Avatar
O/D ratio for NV4500
NMCTD,
Thanks for the finial gear ratios, that really helped out.
Bob
Old Jan 30, 2008 | 12:55 AM
NMCTD's Avatar
anytime!!!!
Heres a couple really cool gear calculator spreadsheets for you guys to run the numbers with, makes it nice if your thinking about changing gears or tire sizes.
http://cumminsdatabase.com/read.php?id=145
http://cumminsdatabase.com/read.php?id=155
Old Jan 30, 2008 | 10:38 PM
Bosshawg600's Avatar
2100 rpm I run 75 mph. got 3.55's and 33" tires.
jefjsak
Jan 15, 2015 03:44 PM
53 willys
31
Jan 31, 2008 02:24 PM
skeeter
Jan 18, 2006 03:17 PM
dieselnewbie
Apr 13, 2004 12:00 AM
fishin fever
Feb 22, 2004 08:32 PM
