4x4 Transmission Output Spline Size
Old Mar 27, 2006 | 05:58 PM
NHDiesel's Avatar
Well I received some free shafts from Goerend Bros. that they pulled out during trans rebuilds to use for an adapter shaft for my Spicer conversion. I am a bit confused though, since the shafts I received are all 1 1/4" in diameter at the spines that enter the transfer case. I found on a couple sites that the diesel 4x4 shafts should be 1 1/2". Does anyone have a 4x4 transmission out of a truck that they could measure the output shaft of?
Jim
Old Mar 28, 2006 | 07:35 PM
NHDiesel's Avatar
Just an update. I checked the shafts tonight, and they are only 23 splines, and the same size as 1/2 ton trucks and Dakotas. I verified this by fitting the shafts to a Jeep Wrangler np231 transfer case I have, and tghey fit perfectly. Common sense tells me our diesels use larger shafts, but I e-mailed Goerend Bros. to see if they may have sent the wrong shafts, and the reply said that all of the shafts i got came from diesel transmissions, a 47rh and a 47re.
So if anyone could possibly check on their stock diesel transmission output shaft size, I'd very much appreciate it. Otherwise I'll be pulling my t-case this weekend just to measure the shaft in my transmission.
Jim
Old Mar 29, 2006 | 07:58 AM
Greguw's Avatar
Smile Re: shaft
I just measured a 47re output shaft ...it's 1.220 ... the trany is out of a diesel .
Greg
Old Mar 29, 2006 | 08:18 AM
Mcmopar's Avatar
I hate to "bust your bubble" but they use the same shafts in the 46 and 47 RE. The output from the X-fer case is larger, but the tranny shafts are the same size.
Old Mar 29, 2006 | 08:19 AM
Geico266's Avatar
Dodge is about all Dave Georend works on. I'm sure he would send you the right stuff.
Old Mar 29, 2006 | 07:14 PM
NHDiesel's Avatar
Thanks very much! I'm very surprised at the size of the output shaft. I had an old Jeep J-20 T-18, and the output shaft was quite a bit larger than the common 1/2 ton shafts, and common Jeep 23 spline shafts. I was just confused because a couple sites, such as this one: http://dodgeram.org/tech/transmission/nv4500_spec.htm list the size as 1 1/2" with 29 splines. That page is for an NV4500, but the t-cases are the same. Thanks for the input!
Jim
DodgeFreak
Jul 25, 2012 11:10 AM
MARF75
Apr 10, 2012 01:48 PM
SPINPOSI
Aug 21, 2006 11:42 AM
clc900
Nov 18, 2004 07:46 PM
DaNuGuy
Oct 2, 2004 03:26 PM
