4 wheel drive
Old Jun 11, 2008 | 12:18 PM
deking1970's Avatar
4 wheel drive
Is the way the 4 wheel drive engages in a '94 5 speed the same as in a '98 automatic. The 4x4 in my Dad's '94 works flawless but the '98 has been intermittent and finally quit working at all.
Old Jun 11, 2008 | 12:25 PM
Mcmopar's Avatar
They should be the same. Climb under the 98 and look to see if the metal lines have rusted or the rubber lines are shot. They also connect to the firewall just to the drivers side of the truck. You can trace these.
Old Jun 11, 2008 | 12:37 PM
deking1970's Avatar
Thanks, I'll have to do that as soon as spring actually gets to Montana and I have a dry place to do it.
Old Jun 23, 2008 | 09:30 PM
tex04's Avatar
In my 96 the vacuum motor had a hole in it. I ended up installing a Posi-Lok cable. Heres a couple websites.
http://www.4x4posi-lok.com/
http://quad4x4.com/
Old Jun 25, 2008 | 07:12 PM
turboman1's Avatar
I would say there is something wrong on the vacuum system. If it was intermittently working and then totally stopped I would say the vacuum pump was going bad and finally just went.
Hope this helps
Adam
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
Teddy
Nov 2, 2002 01:56 AM
