2 inch coil spacer install
Old Jun 19, 2008 | 01:27 PM
Brendan's Avatar
I am about to install a set of 2 inch coil spacers and was wondering what the best way to go about it was? Any first timer tips would be great!!
Old Jun 20, 2008 | 05:07 PM
kawi600's Avatar
You can unbolt all the stuff in the front like the tie rod, the trackbar and the sway bar links and lower it on a jack until the springs get slack.
I dunno how possible it would be to lower the axle and use spring compressors.
If you do use compressors, Id back them up with tie-down straps just in case. Dont put your hands above them if you can avoid it.
Old Jun 20, 2008 | 07:55 PM
BCB's Avatar
BCB
thats how i did mine, worked great
getrdun
16
Sep 9, 2008 07:28 PM
KKoteles
30
Apr 16, 2008 11:07 PM
KKoteles
Jun 19, 2007 06:06 PM
GONZO86
39
Sep 9, 2003 05:58 PM
jt
Mar 20, 2003 08:54 PM
