1998 12 valve that flutters when driven
Old May 14, 2003 | 09:48 PM
dieselman24's Avatar
This truck is such a nightmare first the clutch goes out then the all mighty of them all the big killer dowl pin took its toll too so now it flutters,no one seems to know where to begin started with the timing and that didnt fix it or help it no fuel leaks any where it does have the marine 370 injectors in it though but that could surely not have a thing to do with it and no fuel plate at all advanced as far forward as possible on the pump as well.I have had several of these trucks and this is the only one that flutters so i know that it is not from the plate being missing of the injectors cause there new from bosch and also it is starting to get hard to shift the gears at a stoplight with clucth pushed in just put a new southbend clutch in it before the dowl pin deal so it dont have 600 miles on everything any info would help me out a whole lot and please email it to dieselman24@hotmail.com i never use the toddj@rollaneet.org address again thanks alot for any help...
Old May 15, 2003 | 12:33 AM
MCummings's Avatar
Re:1998 12 valve that flutters when driven
Actually, the 370's and a 160HP Pump are not a good combination. That wil cause flutter. (or surge)<br><br>As far as shifting. I have that problem too. It could be a worn shift fork, a bad throw out bearing, or your Clutch hydraulic's going out.<br><br>But I'm not a 12V guy... Yet <br><br>Merrick Cummings Jr
Old May 17, 2003 | 07:54 PM
WKener's Avatar
Well, it's a '98 5spd so it should be a 215 pump, no problems with the 370s there... When you say &quot;flutter,&quot; do you mean it is stumbling as you increase rpms? Consistently at similar rpms? Have you tried putting a plate in it just for verification purposes?<br><br>Did this problem arise after the KDP faliure? When the KDP failed, what damage was done and which components were repaired/replaced?
Old May 18, 2003 | 01:22 PM
bulthisl's Avatar
Define flutters a little more.<br>Does it have a 4k gov. kit?<br>And was the gov lever adjusted ?<br>Of course with no plate that should not be the prob.<br><br> : Eddie : 8)
Old May 18, 2003 | 10:13 PM
well it is kind of hard to explain flutter today i noticed it around the 1100-1900 rpm range it almost feels like you are pulling the plug wire off a smallblock and then putting it back on,and i do not have the gov kit yet but i think i will get it this week and have done nothing to the gov,just almost a dead miss but it goes away when under alot of higher rpms above 2000 i have put the plate back in too and it did not help i was thinking about maybe having the timing set up just about 3 degrees or so and see if that helps i just want it go away and to the lucky person out there that makes it go away i will buy you a steak dinner it is real anoying trying to drive it in town thanks todd (i never got to drive it much before the kdp but it did do it then too)
Old May 19, 2003 | 09:55 AM
Smokee's Avatar
The flutter that you are describing sounds like the 370's. If you are going to add the 3000gsk, you may have to play around with the tensioning of the hold-down spring keepers.<br><br>Someone will be able to advise you on whether to loosen the keepers or tighten them once you give details of the stumble.<br>george
Old May 19, 2003 | 10:25 AM
Rammin On's Avatar
Give me a call .... 573-265-5595 ... I'll try and help you out ..<br><br>Keith
Old May 20, 2003 | 09:19 PM
Ok folks Keith the Rammin on man has fixed the flutter in the 12 valve and let me tell you that the truck that this man has will sure enough impress anybody that gets near it.And ohh by the way i dont think that there is a PowerPoke out there that will even come close to running with this thing it is AWSOME thanks again Keith <br> <br> Todd
Old May 20, 2003 | 09:40 PM
MnTom's Avatar
So tell us how you fixed it.
Old May 21, 2003 | 12:19 AM
Im not sure what the the darn little object is called but it is like the afc or on the lines of that. it is where the plate is suposed to go the foot was bouncing against the spring or something like that,Heck Rammin On can tell you how he fixed it im not sure but it is fixed thats i was worried about and i really think that this site is 10 times better than TDR ever thought about being.Everyone is is so nice and try to help another person out.. I would like to know about any diesel truck pulls that will be within about 300 miles of St.Louis to go to over the summer. Again thanks for all the help
Old May 21, 2003 | 12:00 PM
dsljunkie's Avatar
Hey Rammin On,<br> Is it possible for you to explain how you fixed this flutter over the net or would it be better if I gave you a ring? Im experiencing the same &quot;flutter&quot; and need to get it fixed.<br> Thanks <br> Wheels
Old May 22, 2003 | 04:00 PM
turbo thom's Avatar
Well I had the same thing and I fixed mine. I will tell anybody how I did it. I took out the 370's , reinstalled the 215's. Maybe lost 40 hp and man does it run now. Yeah, with the 3K governor springs.<br><br>..Preston..
thechoochlyman
Sep 23, 2012 09:31 AM
mullishacrew
Mar 20, 2008 12:43 AM
12 flapper
13
Jan 7, 2008 05:19 PM
jeeptjstud
Mar 12, 2006 02:30 PM
