1995 hard start
Old Aug 15, 2009 | 10:51 PM
ohiostate24's Avatar
1995 hard start
My father has a 1995 all stock cummins and it has a problem . He has told me that the last couple weeks, when he goes to start the truck for the first time that day it doesn't want to fire right away, this problem has progressively gotten worse over the couple weeks to where it wants to crank over several times before it fires. He did say that when it gets started it wants to spit and sputter but once he gets it down the road a little ways it runs fine. He also did say that even after the truck sits while he is at work, its like the truck is perfectly fine. Then the next day comes and he has the hard start and sputtering issue till it gets warmed up....I told him the is the one place where he can get his problem solved...Dont let me down guys...
Old Aug 15, 2009 | 11:03 PM
Ramdriver15's Avatar
fuel leak somewhere... truck is airbound after it sits...
Old Aug 15, 2009 | 11:11 PM
Swarthy Dago's Avatar
fuel siphoning back to the tank or air is getting pumped forward ? Once the truck is running ok, try spraying some ... WD40 ??.....around the intake areas, guys what can he use there ? We use to use ether but that's not to good on engines in great amounts.
Old Aug 15, 2009 | 11:22 PM
rich's Avatar
check the return line behind theinjection pump its a rubber line and can crack and allow air without seeping fuel out my 12v had that nproblem
Old Aug 16, 2009 | 07:36 AM
46mech's Avatar
Yep, check the fuel line behind the injection pump. Beings it's a '95 and stock, I'd just change out that fuel line anyway.
Old Aug 16, 2009 | 08:29 AM
John Faughn's Avatar
Check fuel pressure .
Old Aug 16, 2009 | 09:31 AM
Thanks guys. I will tell him today and let ya guys know what he finds.
Old Aug 21, 2009 | 08:28 PM
HONKEYTRUCK12's Avatar
My 95 did the same thing. Ended up being the fuel line behind the pump. The sucker is a challenge to change! Man up dude.
Old Aug 21, 2009 | 10:44 PM
aar_man's Avatar
I wish I had found this thread before I asked the exact same question......12V Hard Start? My recently acquired 95 is starting to do the exact same thing.
I will check the return hose on mine. I hope that is the problem and that it cures the hard start.
I will be watching for ohiostate24 reply.
John
Old Aug 22, 2009 | 06:30 AM
CarlJensen's Avatar
The best move is to replace the whole fuel line system. If one hose is starting to leak others may, they are all the same age. Did mine a couple of years ago and bypassed the whole old line runs with new diesel rated hose.
Old Aug 22, 2009 | 10:49 AM
infidel's Avatar
Carl is right, the best move is to abandon the entire fuel supply and return system and replace it with quality diesel rated hose all the way from the engine to the tank.
Do it once and be done with it.
Just make sure it's diesel rated hose. Gasoline hose will melt with diesel.
Robertschas
Jun 3, 2008 04:11 PM
Robertschas
Aug 2, 2006 01:07 PM
gabbyfan
Jun 15, 2004 05:35 PM
Farmer
Nov 28, 2003 03:42 PM
