1991 w350 into 1993 ramcharger
Old Dec 17, 2017 | 09:53 PM
Gmoody425's Avatar
Post 1991 w350 into 1993 ramcharger
i am looking into doing the swap and was wondering if anyone has done it. i have a full w350 running gear (axles motor trans etc.) and was looking at buying a 1993 ram charger. i was wondering what the wiring mess is going to turn out to be. is it mostly plug and play with the black plug with yellow core on the firewall or do i have to take the dash out and put the diesel wiring harness in under the dash. i was also wondering what motor mounts do i use. do i use the ones out of the truck or out of the ram charger (360 v8 magnum). or if anyone has done the swap and could link me to there build thread that would be great.
Old Dec 18, 2017 | 07:18 AM
Many of us here have done that swap, me included.
If you want it to all work and look like stock, you will need to change the dash, engine and engine bay harnesses along with the gauge cluster and message center.
You will use the diesel motor mounts on the RC crossmember.
Go to the first gen section and search Ramcharger, several threads should come up.
Is your W-350 a dually or a single rear axle W-350?
Welcome to DTR!
LaHo
Mar 10, 2013 12:45 PM
lassy
May 19, 2012 06:46 PM
Don L. Robbins
Feb 12, 2010 07:42 PM
jcb
Jan 31, 2006 08:40 AM
