12V heads the same
Old Apr 2, 2005 | 11:24 PM
msing's Avatar
12V heads the same
Are all 12V heads the same the ones used in dodges I am thinking about finding a used head getting it hotanked and magnifuxed and doing some porting then sending to Peirs to have it Oringed. Are there better castings than others? I what to do it this way so I have less down time.
Old Apr 3, 2005 | 12:37 AM
Fueling around's Avatar
Buy an aftermarket head. They are casted much better than original heads and the material machines better. Piers offers them.
Old Apr 3, 2005 | 01:53 AM
lucas5477's Avatar
Fueling around....When you say aftermarket head what do you mean?
Are you saying that there is a better casting then a cummins casting?
Im looking for a new head and I have not seen much on the subject......
Could you give some part numbers to aftermarket heads if you have any or where to get them? Peirs....I thought he sells ported cummins castings heads....?
Thanks,
Lucas
Old Apr 3, 2005 | 10:34 AM
The 12 valve heads I've seen do not come in a Cummins box. Local shop gets them from a place down by the Twin Cities.
I thought I had a photo of a side by side comparison between the blocks, but cannot find it. Casting is much thicker in the bosses around the exhaust side head bolts. The place that does his porting says the material is much better than stock heads.
I was going to o-ring my head laast year whent he gasket blew. Mike talked me into waiting to see if I wanted/needed o-ringing. If I do, then get a new head, port it, and of course o-ring.
-John
J Lent
60
Nov 3, 2009 09:14 PM
mhuppertz
Jan 4, 2008 06:44 AM
jmccart
Jan 18, 2007 03:26 PM
