12 Valve Cummins Very Poor Acceleration
Old Oct 10, 2013 | 09:30 PM
Ironduke10's Avatar
My 1996 Dodge 12 Valve just started to very poorly accelerate from a stop. Once it does get going it does spool up. Could this be from a dirty fuel filter or the turbo going out?
Old Oct 11, 2013 | 01:20 AM
chariotdriver's Avatar
Check the fuel pressure or change the fuel filter......did you get a bad batch of fuel? Maybe a sticking waste-gate. The turbos usually last a very long time.
Old Oct 12, 2013 | 06:38 PM
Ironduke10's Avatar
Turbo seems to spin freely... no play in the shaft. Changed fuel separator and the engine accelerated as normal.
Automatic transmission shifts a little bit erratically.
Recently had the Throttle Position Sensor and Transmission (47RE) Valve Body Assy replaced. However the mechanic recommended also having the TCM updated to latest calibration for better operation.
No engine light, but took the truck over to Oreilly's and had the codes checked.
Results:P0122 & P0123: TPS / Switch a circuit low input.
Also code p1757: Gov Pressure above 3 PSI in Gear with 0 MPH.
Guy at Oreilly's believed these could be residual codes that the shop did not clear after the work was completed since there is no current engine check light staying on now.
Old Oct 12, 2013 | 08:33 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Change the dirty fuel filter
Old Oct 12, 2013 | 08:50 PM
Ironduke10's Avatar
As stated, I have. Thanks
Old Oct 12, 2013 | 09:32 PM
Admin Team Leader
Service the fuel heater strainer assembly....they will get clogged up with an amazing amount of crud
Old Oct 12, 2013 | 09:38 PM
Ironduke10's Avatar
Question
Is this the fuel heater strainer assembly?
http://dodgeram.org/tech/dsl/filter/pre-filt_clean.htm
Old Oct 12, 2013 | 10:44 PM
That's it.....you can get a new strainer and gaskets from Genos or Cummins for less than $10. While your are at it, get rid of the worthless fuel heater......just need to remove the bolt thingy holding it on then it with the fuel heater drops free allowing the bowl with the strainer to screw into the same hole. It really is worthless and causes problems down the road when it starts leaking on the suction side causing starting issues when the fuel system looses prime.
Old Oct 13, 2013 | 10:23 AM
Ironduke10's Avatar
Thumbs up
Old Oct 13, 2013 | 11:01 PM
wish I would have seen that video 10 years ago
kkime
Mar 25, 2010 11:05 PM
AkitaSumo
50
May 1, 2009 07:38 AM
fschiola
Jun 22, 2008 09:24 AM
gr898
Feb 27, 2005 07:14 PM
PADZZ
May 24, 2003 09:57 AM
