6BT swap?
Old 01-12-2008, 09:13 AM
93Fury's Avatar
6BT swap?
Does anyone know of anyplace (websites, shops, whatever) to get swap parts for a Cummins going into a '90 fullsize, 1 ton GMC/Chevy? I have the engine and trans, 6BT/Allison auto., but if I can't find anything to do it I guess it's not worth it. I just really need engine and transmission mounts, the rest is no problem. Thank you if anyone can help.
Dakota
Old 01-12-2008, 05:12 PM
mwlu711's Avatar
fordcummins.com might be able to help you i think he does chevy too
Old 01-12-2008, 05:15 PM
mwlu711's Avatar
sorry about being repetative im computer illiterate
Old 01-12-2008, 05:19 PM
93Fury's Avatar
I checked them out and the only thing they were showing was a swap into a K-5. I tried checking ChevyCummins.com and it said the site was under construction. Thanks for the help though.
Old 01-12-2008, 05:28 PM
Dieselnick's Avatar
Try cummins-conversion.com. Your type of swap has been done many times; there should be a lot of info out there.
Nick
Old 01-12-2008, 05:31 PM
torquefan's Avatar
www.destroked.com has many cool adapters and stuff. Mostly geared towards Ford swaps, but you might find some useful stuff.
Old 01-13-2008, 10:06 AM
93Fury's Avatar
Thanks guys.
Old 01-13-2008, 11:26 AM
12valve@heart's Avatar
Check http://www.autoworldmt.com/Page_11.html
Also check www.cummins-conversion.com for tips
Old 01-13-2008, 12:51 PM
1-5-3-6-2-4's Avatar
theres a guy on ColoradoK5.com that manufactures swap parts for cummins to chevy swaps like motor mounts and dropped engine crossmembers bolt in stuff.
I plan to get some swap parts from him to convert my new to me '97 crewcab dually.
i've chattedf with him a couple times seems like a straight shooter.
I can find his email if you want.
Old 01-14-2008, 07:53 AM
93Fury's Avatar
Yeah, thanks that would be great.
Old 01-18-2008, 09:10 PM
turbos10's Avatar
You can buy as set from a guy on 4btswaps.com named scott. He goes by CrewCab59. He also sells a front crossmember or you can modify your own. It will have to be dropped about 4 inches in the middle to get good clearance. The tranny mounts will prolly be on you. If you have a welder and some patients it is not too bad. I built all of my mounts in about a half day from scratch. I use cardboard to make templates and get them perfectly fit first.
The way I did it was starting with the engine crossmember modification. Next you have to get the engine and transmission mocked up using jacks or wood blocks. I just used wood blocks under the pan and on the sides to wedge it. Before setting the engine in I bolted 1/4" plate to the engine so I had something to weld to. Then I made carboard templates to fit in the factory GM isolators. Last I cut them from steel and bolted them to the frame and welded it to the engine plates. I picked up the engine and removed the mounts for final welding and gussets.
I can send you picks if you want, or post them here.
Old 01-18-2008, 10:37 PM
Yes the guy on ColoradoK5 is Crewcab59..........same guy I'm sure.
Old 01-19-2008, 12:46 AM
Tate's Avatar
He's been on here as well. Was asking about some delivery valves out of a 4bt p-pump, if I recall.
Old 01-19-2008, 10:30 AM
jrsavoie's Avatar
I am interested in the details of a 4BT or similar swap. I don't need much more power than the stock 6.5 offers. I want something more dependable and easier to work on. I also want to get away from the L480E's
Old 01-19-2008, 10:34 AM
jrsavoie's Avatar
Dakota
Could you give me some details on your Allison auto?
4 speed?
Part number or what it is called.
I've always been a GM guy and don't know much about other manufacturers engines, Trans etc.
Quick Reply: 6BT swap?
