1974 W200 Crew Progject
Old 10-19-2016, 10:34 PM
  #46
BHD
BHD's Avatar
Well this project has hit a snag. The donor engine, which runs like a scalded ape, has a dowel pin that came loose. At some point, after it decided to vacate its residence, it chipped a cam gear tooth, broke the gear housing, and lived in the pan until, at some point, it got stuck on the magnetic drain plug and was gone forever. Good thing I drink, because I may have become upset when I found this problem today.
Old 10-20-2016, 04:17 PM
  #47
73CrewCab's Avatar
Oh no...I'll have a Miller for you...
Old 11-06-2016, 08:39 PM
  #48
BHD
BHD's Avatar
After replacing the front gear cover and every seal and gasket that was leaking oil I finally got the engine and transmission mated together and installed. I had to relocate 2 crossmembers and I need to get all 3 drives shafts built. Progress is slow but moving ahead.
oliver foster (11-07-2016)
Old 11-06-2016, 08:41 PM
  #49
BHD
BHD's Avatar
Old 11-07-2016, 11:47 AM
  #50
73CrewCab's Avatar
Glad you got it back together. I'm really jealous that you have a 5 speed with a man pedal.
Old 11-07-2016, 05:20 PM
  #51
BHD
BHD's Avatar
Thanks man. The amount of tedious work is endless and I am not even messing with the body! I am not sure of how many "man hours" I have invested but its over 75. I do repair work on the side for customers and I told everyone that I am taking off the months of October and November. So I would like to have this thing chugging around on its own very soon.
And to reply to your quote, I have no love for the slush box.
Old 11-08-2016, 06:34 AM
  #52
Received 2,393 Likes on 1,576 Posts
Nice looking work coming from a guy who hates slush boxes too!
You may want to look into a little extra bracing for they divorced mounted NP-205.
I had that set up on my '72 with 38s and it would rock forward and backward as I shifted it from reverse to a forward gear and gave it some power. Using the "man pedal" of course.
Old 11-08-2016, 11:52 AM
  #53
BHD
BHD's Avatar
I was surprised that the OE transfer case crossmember was riveted and welded in. I do plan to build some kind of bracing it. Did you brace the crossmember or the transfer case?
Old 11-08-2016, 06:56 PM
  #54
I installed a special bracket that was a brace to the T-case.
PM your E-mail address and I will send you a picture of it.
Old 11-09-2016, 06:25 PM
  #55
BHD
BHD's Avatar
PM sent
Old 11-10-2016, 09:10 AM
  #56
I sent a few pictures. It was a rather crude brace I had made as I was using the truck basically as a trail rig / mud truck.
It did fix the problem which helped me not blast out the rear driveshaft as often.
The U-joint would bind with the large lift, and the really short driveshaft on a short bed truck with that divorced NP-205 T-case. The rocking T-case made it only bind more.
You should have a much better driveshaft angle with less [no?] lift and the longer crew cab length.
Old 11-10-2016, 11:29 AM
  #57
BHD
BHD's Avatar
I got them and thanks. I will try to do something similar. With the cost of the two shafts I just had made, I can't afford to blow one out because I didn't take the time to truss up the transfer case.
StealthDiesel (11-10-2016)
Old 11-13-2016, 03:53 PM
  #58
BHD
BHD's Avatar
I pulled it out today to make some money in the shop. I'll be happy when Johnny Tractor is not the motivating force.
Old 11-13-2016, 03:54 PM
  #59
BHD
BHD's Avatar
Old 11-13-2016, 05:44 PM
  #60
Looking good!
Quick Reply: 1974 W200 Crew Progject
