Sponsored by:
Sponsored by: DashLynx
Question about Dr performance preditor 2013
Old 09-25-2008, 09:08 PM
JOESHTRDDSL's Avatar
I just recieved mine in the mail. I was wondering from the guys that have these, what do you do with the yellow wire. I know it is suposed to go to a switch but what do you do with the other side of the switch. Does it go to ground or power. Thanks, Joe
Old 09-26-2008, 10:59 AM
No one has any info?????
Old 09-26-2008, 11:04 AM
elirandolph's Avatar
I didn't connect mine to anything. what kind of switch are you using? Does this turn the module on and off?
Old 09-26-2008, 11:08 AM
Nate-03 D's Avatar
I think the module he has is adjustable. On some modules you can select settings like tow/performance/off, ect.
From the sounds of it you have the same box I have, you connect it next to the rail and it's not adjustable.
JOESHTRDDSL- Sorry, I don't have any useful info for you. Im sure someone else will chime in.
Old 09-26-2008, 12:09 PM
How do you like your preditor Nate?
Old 09-26-2008, 04:38 PM
Nate-03 D's Avatar
I love it to death. It's the non adjustable module, it just plugs in and gives me an extra 80HP. It is a great box to stack with. Running the Dr.P and my Smarty JR is a good combo. I don't ever have any codes thrown, the box is 5 years old and it's nothing short of great.
I think it helps with my top end as well. Just running the box I have by it's self is ok, but it's not the greatest. I definitely think it is one of the better modules to stack with. All in all, I would never get rid of it.
Old 09-26-2008, 04:44 PM
bigjohn04's Avatar
As far as the yellow wire if you ground it cuts the power back to stock. You can wire it to a simple on-off switch and ground the other side of the switch so you can turn off the extra power when towing or whatever. Hopefully that makes since.
Old 12-23-2008, 02:06 PM
Does anyone know what the other wire is for? I am getting ready to hook the yellow wire to a switch to turn it off and was curious what the other one is for.
Old 12-23-2008, 03:11 PM
ratsun's Avatar
I just bought this one from member francis
https://www.dieseltruckresource.com/...t/23169/cat/12
Its the 2014 model that had a switch added.
He told me the yellow goes to the switch and the other end goes to ground.
I dont quite know how it does it but he said it gives it three settings off/tow/kill
Old 12-23-2008, 03:22 PM
ratsun's Avatar
Check this out
Step by step video
http://revver.com/video/1331398/dr-p...odule-install/
Old 12-26-2008, 07:47 PM
phantom 309's Avatar
the yellow wire is to connect to a toggle switch, then the ground, it works as a on/off switch
or you can buy the triple play switch from dr.p and do the same thing do have an off, high, and medium power settings
vwjunkie53
13
12-20-2007 12:57 PM
rockjeep
10-03-2007 06:54 PM
vwjunkie53
15
09-29-2007 07:29 AM
Bosshawg600
03-29-2007 10:08 PM
shambo
01-23-2007 07:42 AM
Quick Reply: Question about Dr performance preditor 2013
