ISSPRO Turbo Temp Monitor
Anyone have trouble with these after they installed them? I've had mine for about 2 years now. All of a sudden I'm blowing the 2 amp fuse in the ignition system (#22). That caused some major issues with my SKIM module and key code. Blew through about 5 fuses till the SKIM had to be replaced as well as a new ignition and key. Un-mounted the monitor and sent it in to get tested to ISSPRO. They inspected it and replaced the relay and a transistor, sent it back to me. I then soldered the connections for power to the ignition (previous had them spliced in) and it worked for 2 days and now the same results are happening again. Blowing the 2 amp fuse, and now I think the SKIM module is toast again.
Has anyone used this monitor and/or had any issues like I'm having? I love this thing, pull the key out and lock the truck and it shuts off when it reaches the proper cool down temp. Thanks.
BlackSheep5
13
04-04-2007 11:15 PM
bpdp379
02-17-2007 01:35 PM
rattle_rattle
06-28-2003 11:48 AM
