2008 OEM lift pump replaced /no fuel at filterhousing
Old 02-07-2016, 08:42 AM
Batavia's Avatar
I have bumped starter after replacing in tank fuel module and left on run for several seconds over and over with nothing running out of filter housing.
After cycling there is a puff of vapor coming down from filter housing out of pressure line. 2008 C&C 3500 DRW with rear tank. Im expecting the pump to run it up to filter at least. Is it because the pump line isn't full yet ? Before I dug the pump out it ran and started perfect except I was getting a ding ding overhead warning SERVICE REQUIRED/SEE DEALER NOW,(no codes)then limp mode. I wanted to make sure it wasnt the pump being weak so I replaced with a new OEM frm Napa.
Old 02-08-2016, 03:42 PM
Batavia's Avatar
Is this fuel delivery related ? Right by firewall
Red3quarter
09-20-2008 11:30 PM
Chrisreyn
05-17-2008 10:55 PM
buba1960
02-19-2008 03:27 PM
Chrisreyn
01-13-2008 06:30 PM
89dieselkong
12-18-2007 11:38 PM
Quick Reply: 2008 OEM lift pump replaced /no fuel at filterhousing
