95 DODGE AUTO PCM CAVITY ID (longfile)
Old 02-12-2012, 11:25 PM
mt72916's Avatar
Post 95 DODGE AUTO PCM CAVITY ID (longfile)
having sold my 95 i thought i paste this up before i deleted it perhaps someone may need it.
PCM CAVITY IDENTIFICATION
1995 DODGE AUTOMATIC
WIRE
CAVITY CIRCUIT GAGE COLOR FUNCTION
1 K1 20 DG/RD WATER IN FUEL
2 NOT USED
3 A14 16 RD/WT FUSED B+
4 K4 20 BK/LB SENSOR GROUND
5 NOT USED
6 K6 20 VT/WT 5 VOLT OUTPUT
7 K7 20 OR 8 VOLT SUPPLY
8 NOT USED
9 F18 18 LG/BK FUSED IGN SW OUTPUT (START/RUN)
10 T6 20 OR/WT TRANS O/D SWITCH OUTPUT
11 Z12 16 BK/TN GROUND
12 Z12 16 BK/TN GROUND
13 NOT USED
14 NOT USED
15 S22 20 OR/BK HEATED AIR RELAY #2
16 S22 20 OR/BK HEATED AIR RELAY #1
17 NOT USED
18 NOT USED
19 NOT USED
20 K20 18 DG GEN FIELD CONTROL( REGULATOR VARIABLY GROUNDS alt)
21 K21 16 BK/RD INTAKE AIR TEMP SENSOR
22 K22 20 OR/DB THROTTLE POSITION SENSOR
23 NOT USED
24 K24 20 GY/BK ENGINE SPEED SENSOR (CRANKSHAFT POSITION SENSOR)
25 D21 20 PK SCI TRANSMIT
26 NOT USED
27 C20 18 BR AIR CONDITIONER REQUEST SIGNAL
28 NOT USED
29 V40 20 WT/PK STOP LAMP SWITCH OUTPUT
30* T41 20 BK/WT PARK/NETURAL POSITION SWITCH SENSE GROUND
30* Z12 20 BK/TN PARK/NETURAL POSITION SWITCH SENSE GROUND
31 G14 18 PK/BK TRANSMISSION TEMP LAMP DRIVER
32 G3 20 BK/BK MALFUNCTION INDICATOR LAMP (CHECK ENGINE)
33 V36 20 TN/RD VEHICLE SPEED CONTROL - VACUUM SIGNAL
34 C13 20 DB/OR AIR CONDITIONER COMPRESSOR CLUTCH RELAY CONTROL
35 G86 18 TN/OR WATER IN FUEL
36 G85 18 OR/BK WAIT TO START
37 T18 20 LG/OR TRAMSMISSION CONTROL MODULE
38 NOT USED
39 NOT USED
40 NOT USED
41 NOT USED
42 T54 16 VT TRANSMISSION TEMPERATURE SENSOR
43 G21 20 GY/LB TACHOMETER SIGNAL
44 NOT USED
45 D20 20 LG SCI RECEIVE
46 NOT USED
47 G7 20 WT/OR VEHICLE SPEED SENSOR
48 V31 20 BR/RD VSC SWITCH - SET (SPEED CONTROL)
49 V32 20 YL/RD VSC SWITCH - OUTPUT (ON)
50 V33 20 BR/RD VSC SWITCH - RESUME/ACELL
51 K51 20 DB/YL ASD/FUELPUMP RELAY CONTROL
52 NOT USED
53 V35 20 LG/RD VEHICLE SPEED CONTROL VENT SIGNAL
54 K54 20 OR/BK TCC SOLENOID CONTROL (TORQUE CONVERTER CLUTCH)
55 T60 20 BR OVERDRIVE SOLENOID CONTROL
56 NOT USED
57 A142 16 DG/OR ASD RELAY OUTPUT
58 NOT USED
59 NOT USED
60 NOT USED
ebanezar
03-04-2011 11:35 PM
Big Perm
12-18-2007 08:44 PM
zspear1
17
06-04-2007 10:21 PM
DustyRock
11-27-2004 04:38 PM
Quick Reply: 95 DODGE AUTO PCM CAVITY ID (longfile)
