No dash or exterior lights
I used my trailer all weekend, this morning I went out to find my dash lights, marker, tail and trailer lights aren't working.
I checked the fuses, first none are marked lights, but didn't find a bad one.
Did I damage my headlight switch?
Thanks
Thanks
It isn't unheard of for the multiswitch to die in these trucks hopefully someone on this board who knows more about the electrical system than I do will chime in before you go down that road.
I think, I haven't checked to be sure, but my trailer lights may have shorted when I put the ramps back on.
I did that once before on my 1992 Dodge and had to replace the headlight switch.
I am surprised there is no fuse
I found it!
I Googled the problem, and found out there is a second fuse block under the hood! Sure would be nice if they had put that info in the owners manual!
There was a fuse for trailer/lights that was bad due to a bad wire on the trailer.
genosgarage
Geno's Garage
09-09-2014 08:36 PM
NoSparkplugs
17
05-17-2009 10:36 PM
CHarlan
08-06-2003 08:40 PM
