I'm not liken this, but
Old 03-21-2014, 04:21 PM
  #31
patdaly's Avatar
Originally Posted by cougar
Thought this kind of weird. There is no lift pump on the engine, only one in the tank. There is a bypass block were the lift pump use to be and there is a relay on the firewall. I heard this was a retrofit from the factory. With a calibrated mechanical gauge I have 10psi at idle. Do I need to do anything? I'm not planning on doing much in the way of performance other than maybe a bigger turbo and exhaust. Cooling for towing.
That's the devils harness Dodge dealers put on these things. I personally reverse them when I get the opportunity.
I would MUCH rather deal with a block or frame mounted pump when it dumps than drop the tank or raise the bed along the road........
Your call, most guys say they last and last, I have had to do 3 or 4 of them..... Not my favorite job.
Old 03-22-2014, 12:46 PM
  #32
SIXSLUG's Avatar
Thats a cheap bypass the factory used to save money on a section of fuel line. You can take it off and run the fuel line directly to the back of the filter. The FASS kit I bought comes with all the fittings.
You will need to locate a stock fuel pick up unit so you can keep the fuel gauge working...Redlinear sells them for about $100.
Don't despair, that is a nice truck you bought...
Old 10-10-2014, 04:05 PM
  #33
cougar's Avatar
$4+ grand and 7 months later. It is starting to come into shape. At least it is a reliable daily driver now.
irocpractice
11-17-2012 01:52 PM
Scotty
09-11-2005 12:37 AM
Luke S
12-15-2002 12:59 AM
Commatoze
13
10-26-2002 04:35 PM
Quick Reply: I'm not liken this, but
