OK, Let's renew our AC system
Old 07-15-2013, 01:10 PM
maybe368's Avatar
Originally Posted by Philip
The place I bought my kit from has the correct number now. I had sent pic's on Friday of the orginal block to the new block. He hadn't found the correct one as of this morning. I called and talked to them. When I gave him that number. He brought it up and compared the pic's of mine.
Mine should be in by Friday.
That's great, the outfit that I bought mine from is in the process of changing all their kits. They advertise the kit as an exact replacement kit, so it is pretty important to them. I just can't believe that we are the first ones ever to have run into this problem. I e-mailed the receipt to them and they are going to return the 20 bucks that I paid for the correct one...Mark
Old 07-15-2013, 04:26 PM
1st Generation Admin
BC847's Avatar
Great write-up.
Old 07-15-2013, 04:29 PM
Philip's Avatar
The company I bought my kit from said just pitch the other valve. It wasn't worth the shipping to them.
Old 07-15-2013, 05:10 PM
maybe368's Avatar
Originally Posted by BC847
Great write-up.
Would that be "sticky" great? Thank you David...Mark
Old 07-15-2013, 05:13 PM
maybe368's Avatar
That is what my guy said also. must have a million of them. Rockauto did the same thing with a lock cylinder, they said to keep it for 2 weeks then I can do what I want with it. It is a 50 dollar part too. Too bad it's no good...Mark
Old 07-15-2013, 05:17 PM
maybe368's Avatar
Great write-up.
Thanks, I found it in the sticky. ...Mark
Old 07-15-2013, 08:32 PM
rrgrassi's Avatar
Glad you used the Nylog!! I discovered it when redoing the A/C on my old MB. Been six years now, using freeze-12. Ester Oil is the best way to go IMHO.
Old 07-15-2013, 08:46 PM
archer39's Avatar
Where did you order the parts from?
Old 07-15-2013, 09:12 PM
maybe368's Avatar
It's an outfit out of San Diego, called buyautoparts.com. They are the same name on ebay, less the .com. Make sure you note the correct part# for the expansion valve...Mark
Old 07-15-2013, 11:10 PM
NE frmhnd's Avatar
Originally Posted by maybe368
You are certainly welcome. I have a feeling that every ac parts catalogue out there has this same error. As a side note, the belt tensioner started squeaking after the ac install. No problem, 15 minute job, right? That is what I thought, the new tensioner came with a 1/2" opening to put in a ratchet to lever it in. Well, I don't know about you, but it was hard enough to slide a 3/8' into, 1/2" is IMPOSSIBLE. I even loosened the shroud up and it cleared space for everything, except the hole . Some idiot aftermarket parts designer thought that if 3/8" is good, then 1/2" is better, NOOOOT!!!!!. I am going to try and get a dremel in there to cut out access space for the tool. What a bunch of dumb bastigeges......Mark
I picked up a serpentine tool kit for a little bit of nothing a while back. Slid right into my tensioner. It has a flat bar instead of a ratchet mechanism.
Old 07-15-2013, 11:27 PM
maybe368's Avatar
Is it 1/2" or 3/8"?...Mark
Old 07-16-2013, 08:16 PM
maybe368's Avatar
To put a fork in it I drove down to Mexico today, rained a lot, high humidity and she got down to 38 degrees. I was a very happy ice cube. I charged it in a very non-scientific way, but it must be very close. I like that I can buy 134a without a license, anywhere and it sure seems to cool very well, andale pues...Mark
Old 07-17-2013, 07:49 AM
Philip's Avatar
Do you still have the stock condensor installed?
Old 07-17-2013, 07:54 AM
maybe368's Avatar
Yes, the condenser and the evaporator are the only original parts left. The system was still blowing very cold when the wire to the compressor clutch broke. I figured that both parts must be good. Did I screw up?...Mark
Old 07-17-2013, 08:46 AM
patdaly's Avatar
LOL, If you were blowing 38 degree air in Mexico on a humid day, not a chance in Hades that you screwed up..........
Quick Reply: OK, Let's renew our AC system
