Let's Screw-Up Your Steering Column With A New Tachometer and Gear Shifter!
Old 01-01-2015, 10:32 PM
  #46
Received 1,332 Likes on 862 Posts
Originally Posted by 1967david
thanks guy got all the imfo i need where do you get the gage pod and tac
You can get the gauge pod off E-bay, or from LMC or Geno's. It's actually for a 2nd Gen.
been looking for isspro r5503 not having much luck help
Geno's garage carry those.
located factoty tac plug but my wires are different colors they are gray /w lire blue srip then black orange then back looked on my 89 parts truck and its the same i have a1992 d350 5.9 a isspro gagage that was reffered to what would be the proper way to wire it please help !!!!!
89 will not have Tach wiring since it does not use a CPS. 92/93 had the factory Tach harness.
Old 08-01-2015, 01:03 PM
  #47
akaroli's Avatar
New to DTR. This thread was lot's of help. I managed to install my ISSPRO EV Tach but for some reason it does not read the RPM. All it does is light up.
I checked for voltage to the tach and it checks out fine. I even did a continuity test all the way to the ECM plug and it beeps and has zero Ohms.
All my wiring seems correct. I went ahead and purchased the wire loom from Geno's and like somebody mentioned earlier that white wire at the harness side has some sort of filter that does not have continuity but the yellow one does.
Can somebody help me sort this out?
Is there some sensor on the engine that needs to be installed? Is a sensor already avail and may be damaged?
I haven't filled out my sig... 92 W250, Inter cooled.
Nate-W250 (04-17-2020)
Hoss
12-10-2005 02:30 AM
DRM
10-24-2005 06:38 AM
DanTana
11-28-2004 05:33 PM
Pa outlaw
10-21-2004 07:35 AM
Quick Reply: Let's Screw-Up Your Steering Column With A New Tachometer and Gear Shifter!
