Won't Start
Old Sep 2, 2008 | 03:36 PM
06RAM2500's Avatar
IOD=Ignition Off Draw It's the fuse that they pull out when they ship vehicles from the factory. It'll be under a yellow pull tab looking thing.
uber_dzl's Avatar
I didnt use the smarty to bring the truck back to stock before disconnecting the batteries, could this be the issue?
Old Sep 2, 2008 | 03:38 PM
06RAM2500's Avatar
Are you able to connect to the ECM with it?
Old Sep 2, 2008 | 03:40 PM
uber_dzl's Avatar
Im gonna go check that fuse again...brb
Old Sep 2, 2008 | 03:41 PM
uber_dzl's Avatar
When i plug in the smarty it gives me the error code #112
Old Sep 2, 2008 | 03:45 PM
06RAM2500's Avatar
I couldn't tell ya, but Bob Wagner could. 1-888-225-7637
Old Sep 2, 2008 | 03:47 PM
uber_dzl's Avatar
I just finished leaving him a message, looks like I will have to find other means for getting to class today. lol
I will check back here later just in case you guys find anything.
Thanks for the help.
Old Sep 2, 2008 | 03:55 PM
uber_dzl's Avatar
WAIT!.. DOnt leave!.. I made a mistkae its not error code 112 its error code 117 I checked the smarty again.
Old Sep 2, 2008 | 03:56 PM
06RAM2500's Avatar
Still here
Old Sep 2, 2008 | 04:01 PM
uber_dzl's Avatar
does that help any..that its error code 117 instead of 112?
I've never had an issue like this before.
06RAM2500's Avatar
Triple check fuse # 28, it's a green 40A square fuse. Be on the radiator side of the panel.
Old Sep 2, 2008 | 04:03 PM
06RAM2500's Avatar
Have you a digital multimeter?
Old Sep 2, 2008 | 04:05 PM
uber_dzl's Avatar
no multimeter, Im gonna check that fuse and then I have to get to school an will be back on later.
Thanks
p.s.
sorry i have to leave in a hurry
Old Sep 2, 2008 | 04:09 PM
06RAM2500's Avatar
No other DTC's? Manual isn't showing anything for error code 117. It does show this,U0100-LOST COMMUNICATION WITH
ECM/PCM
Old Sep 2, 2008 | 04:26 PM
uber_dzl's Avatar
I went outside and checked that fuse and it was fine. However, the batteries have somehow drained without me trying to start the truck and the negative battery cable connector on the driver side battery was hot. I disconnected the batteries again and let it sit(cable got back to normal temperature). Now I connected the batteries again and the negative cable has again gotten hot. I left the batteries disconnected.
Now Im real late to class lol. be back on later.
