Truck quit
Old Apr 27, 2013 | 06:37 PM
snowjoker's Avatar
Truck quit
My 90 Cummins truck just quit the other morning going to work. It just shut off and would not restart.. I changed the fuel filter and still nothing.. I bought a new lift pump and put on it, and waiting for the battery to charge to try it again.. It did fire on starting fluid .. What could be the problem if its not the fuel pump ?
Old Apr 27, 2013 | 06:40 PM
BILTIT's Avatar
fuel shutoff solenoid, very common problem.
Old Apr 27, 2013 | 06:43 PM
snowjoker's Avatar
That must be mounted on the injection pump with the single wire going to it ?
Old Apr 27, 2013 | 06:44 PM
patdaly's Avatar
Yep, the screwed in piece, not the bolt on one on the side, that is the KSB.
Old Apr 27, 2013 | 06:45 PM
snowjoker's Avatar
ok thanks I will get one .. First time the old girl quit on me in 6 years ive owned her
Old Apr 27, 2013 | 08:29 PM
Onemoparnut's Avatar
Make sure the wire has a good connection at the fss and make sure it is getting power.
Old Apr 27, 2013 | 09:17 PM
j_martin's Avatar
^^^^ what he said.
Wouldn't help to change the shut off solenoid if a fusible link or ignition switch, or even just a loose connection is keeping it from getting power.
The most common problem with the fuel solenoid is the quick disconnect terminal on it quick disconnects.
Old Apr 28, 2013 | 05:30 AM
snowjoker's Avatar
I will check it out.. Thanks !
Old Apr 28, 2013 | 06:51 AM
I have even rigged up a wire that clips to the FSS and has a alligator clamp on the other end for the positive battery post.
I hook it up, then start the truck, you pull it when your done.
The truck was a parts / yard plow and the wiring had been HACKED by the PO.
If you ran a quick wire to the FSS and it starts, you know you have a good FSS and it is in the wiring somewhere.
Old Apr 28, 2013 | 05:45 PM
snowjoker's Avatar
There is power going to the FSS but no start.. Guess I have to order one.. Pricy little bustard too !
Old Apr 28, 2013 | 05:51 PM
BILTIT's Avatar
You can gut the fss (pull out the plunger) and use the manual shutdown lever, this will verify it is actually the fss before ordering one.
Old Apr 28, 2013 | 07:10 PM
snowjoker's Avatar
Ok I can do that but where is the manual shutdown lever.. I took the fss off and checked it out then spun it back in
Old Apr 28, 2013 | 08:31 PM
BILTIT's Avatar
A quick search on this forum and you should be able to find a pic of it.
Old Apr 28, 2013 | 08:37 PM
BILTIT's Avatar
From the sticky, where you will find pretty much everything you need to know about these old trucks. Saves us from explaining this to 1000 different people every month.
Post#19 where the cable is connected too in the below link.
https://www.dieseltruckresource.com/...t211283p2.html
Sticky: https://www.dieseltruckresource.com/...t-t102027.html
Old Apr 29, 2013 | 08:13 AM
patdaly's Avatar
NO!
Get the one for the VW, about 10 or 12 bucks, same unit.
