TPS inexpensive and fully adjustable
I got tired of trying to resurrect failing TPS sensors, and it's against my religion to buy a cheap potentiometer in a special genuine plastic box or $250 - $300, so I decided to fix it.
I made an adapter plate and drive coupling adapter for a TPS found on many 91 - 93 Chrysler gas products, available at junk yards for $5 with the connector, or $22 - $45 brand new at auto supplies. The range of said TPS is a little short, so I changed the 5V drive supply to the 8V CPS supply in the same harness. I tested that supply circuit and found that adding the TPS to it would make no difference at all in the CPS function. It takes a dropping resistor to get the adjustment in range, with the bonus that selection of that resistor gives you options, like all out performance, or conservative shifting.
The only alteration to the original setup is removal of the original TPS and drive coupling, and changing the connector.
What do you think?
What do you think?
Differences between this one and the one in the sticky.
1. Original bracket remains in place. An adapter is added.
2. The original drive coupling is not used, and can be saved unmolested if you want to go back to original, or sell it. A new and simpler coupling, better adapted to this TPS is used.
3. The wiring change allows it to be even more adjustable than factory.
pics of said coupler?
oh...and NICE work, love outside the box thinking. I have a pot on mine but it was a $5.00 radio shack deal I wired up myself. it was a cheap enough fix but lacks the variable o/d capability of a real tps...which I prefer, I find with the pot it`ll hunt in/out of od/ more than I like at a given setting.
Here's the mount and coupler installed:
And the parts kit:
One thing I need to do different is make the drive coupler more like a screwdriver. That is to compensate for an unlikely but theoretically possible stuck TPS sensor. Keeps it from jamming the throttle.
The value of the TPS itself will vary from 4680 ohms to 5720 ohms, with an average value of 5200 ohms. I have to map out some pots to determine the series resistor value needed. As I noted on the experimental one, I got a slightly high range with 820 ohms and a 5200 ohm TPS. It works perfectly with my custom tranny. As you can see, this item is highly variable.
Just got back from vacation a week ago, and am digging out from a nasty snow/slop storm. I'll be back.
77machomopar
20
12-11-2009 10:37 AM
burners_banshee
13
08-22-2007 08:36 PM
Luvnacumns
48
06-26-2007 09:05 AM
streetsmoker
11-20-2006 10:29 PM
