no dash lights
Old 10-16-2014, 05:15 PM
1991.5 mopar's Avatar
no dash lights
i have no dash lights. all fuses are fine.blinkers and tail lights only work if the hazard switch is down(hazard lights dont work). previous owner put 4 pillar gauges in and it a wiring mess under the dash. anyone know what it could be?
Old 10-16-2014, 07:28 PM
cougar's Avatar
I would start with unhooking everything the PO did. I hope you have the wiring diagrams and a large pot of coffee.
Old 10-16-2014, 07:34 PM
sooty's Avatar
could be the dimmer on the h-lite switch
Old 10-16-2014, 08:06 PM
I got a new headlight switch I'll see if it does anything. Is it possible the previous owner messed up the switch by trying to tap into the dimmer?
Old 10-16-2014, 08:39 PM
Montana2x2's Avatar
I've found that 99% of the time when you have multiple electrical gremlins all at the same time it is a ground problem. I would start by checking grounds, the one at the core support near the battery is way undersized and tends to give problems.
Old 10-18-2014, 11:16 AM
cougar's Avatar
" tail lights only work if the hazard switch is down(hazard lights dont work)"
This is the giveaway. The PO hacked the wiring on the multifunction switch. The dash lights are a lesser and different problem. Lets get your outside lights working first.
Old 10-18-2014, 05:15 PM
Where is the multi switch located at?
Old 10-19-2014, 10:44 PM
RamGuy84's Avatar
in the column unscrew the Plastic's and it's part of Turn signal switch .
NoSparkplugs
17
05-17-2009 10:36 PM
craneage2001
11-09-2006 07:07 AM
larry30000
02-26-2006 06:29 PM
CHarlan
08-06-2003 08:40 PM
Quick Reply: no dash lights
