Turn Siginal
Old Sep 7, 2010 | 07:35 PM
GumpsVa's Avatar
Question Turn Siginal
Anyboby know the location of the Turn Siginal Relay for a 2004.5 Quad Cab, I just installed LED's on my truck and the Turn Siginal Blinks like a bulb is burned out. Also I get a bulb out on the dash. Want to put in a heavy Duty flasher relay and I dont know where it is
Old Sep 8, 2010 | 09:50 AM
davidj54's Avatar
There is no flasher unit. It's all handled by relays in the IPM. You're gonna have to install resistors to fool the IPM in to thinking there's real bulbs in there.
Old Sep 8, 2010 | 09:41 PM
GumpsVa's Avatar
Thanks for the info thats what Im doing now Got all my LED's form a web site called: WWW.superbriteleds.com
Old Sep 9, 2010 | 01:56 AM
Colo_River_Ram's Avatar
With age comes the cage
They have good products..
Check the bottom of this link for the load resistor kits (sounds like you need 2 of each - installed one per circuit / side):
http://www.superbrightleds.com/cgi-b...rake-turn.html
I mounted mine to a piece of AL strap and spaced it out from the mounting holes (both resistor to strap and strap to bed) with spacers to help dissipate the heat that they create. I had enough clearance lights(all LED) to get the nominal 2 amp load required for the tail light circuit . All that I had to use was the RL-650 Load Resistors to prevent the fast and or no flash on the TS circuits..
stealman1
Nov 9, 2007 11:07 AM
expressfish
18
Mar 11, 2007 04:28 PM
Cowboy71
13
Oct 21, 2002 07:43 AM
