1st Gen Motor Mount ID
Old 07-03-2007, 03:16 PM
mhuppertz's Avatar
The one on the left is the good one from Auto Zone. The middle is a stock, shreadded mound, and the right is the NAPA part. The Anchor mount has the same thickness as the good stock unit but has rubber molded into all the weight bearing surfaces.
Mark
Old 07-03-2007, 04:07 PM
andyr354's Avatar
So the autozone is the one to get?
Old 07-03-2007, 04:09 PM
mhuppertz's Avatar
Just make sure it's the Anchor #2710 and you are golden.
Old 01-15-2009, 02:41 AM
NO_SPRK's Avatar
just wanted to see how those motor mounts worked out for you. everything good?
Old 01-15-2009, 07:17 AM
mhuppertz's Avatar
Even after nearly ripping the rear end out at the drags, no problems at all. They are still perfect.
Old 01-15-2009, 07:21 AM
sdstriper's Avatar
Which one did you chose and do you recall the cost? Thanks!
Old 01-15-2009, 07:42 AM
mhuppertz's Avatar
AutoZone. Don't remember the price, but they were cheaper than the thin, crappy NAPA ones.
Old 01-15-2009, 08:05 AM
sdstriper's Avatar
Cool, thanks. Anyone know the Anchor p/n for the transmission? Just as well do them all at once...
Old 01-15-2009, 08:22 AM
Free89W350's Avatar
I bought mine from Rock Auto .com
Motor mounts part #131 2710 x2 $14.61 ea
Transmission mount #105 2668 x2 $3.09 ea these are the thicker of the 2
#105 2667 x2 $2.82 ea these are the thinner of the 2
All the mounts are Anchor mounts.
Old 09-14-2010, 11:44 AM
coues7's Avatar
Is the left motor mount different than the right motor mount?
Old 09-15-2010, 07:50 AM
Free89W350's Avatar
Nope they are the same
Old 09-16-2010, 01:41 AM
Crazy Matt's Avatar
Why not use poly bushings?
Old 09-16-2010, 12:07 PM
mhuppertz's Avatar
Where might one get such a thing?
Old 09-16-2010, 01:57 PM
coues7's Avatar
Here: PolyBushings.com
Old 09-16-2010, 09:47 PM
Crazy Matt's Avatar
He is also a first genner.
I was the first to violate his '92 pump - It got some timing, gov spring and a lil fuel screw.
Rode in the truck- couldnt tell it had poly bushings in it. Doesnt shake
Quick Reply: 1st Gen Motor Mount ID
