please read could happen soon.
Old 07-02-2007, 11:13 PM
quadman20's Avatar
please read could happen to you.
Found out some very helpful info. There seems to be an issue on some trucks that they won't start all of a sudden. The dealer say's it a failed starter relay. Well my freind has had this happen 3rd time sunday. Also couple other people I know have had same issue. Well as you see by the pictures shown.
1st picture here is the wire that go's to your starter yellow with grey stripe the 2nd pic look at wire by starter ( looking through driver side wheel well)notice how it's resting against that bracket. 3rd is a closer pic. This wire is rubbing and will eventually short out causing truck not to start. I check my truck to night and as you see same issue. The wire has a slight groove already.Dealers are awhere of this a bulliten has just been released. So take a look and make sure this isn't going to happen to you. I just pushed the wire to the lower side of loom.
Old 07-02-2007, 11:15 PM
DECEPTiON21's Avatar
Thanks for the heads up!
Old 07-03-2007, 07:17 AM
HOV
HOV's Avatar
Good deal, thanks for the post
Old 07-03-2007, 07:38 AM
Foxborough's Avatar
Thanks, just checked mine, I'm good. That is a pretty heavy wire, some rubbing would tear it up. It took me a few minutes to figure out where to look ...duh. I did not get my coffee yet..... For others like me look over the drivers front tire and look in.
Old 07-03-2007, 08:49 AM
quadman20's Avatar
My next door neibor had this happen as well ruined his trip. He was hooked up to his trailer and getting ready to pull out and nothing. His was showing copper. Found yesterday pulled it away and she stars just fine now.
You can also see it from the drivers side well right above starter. It loops out of the large loom of wire, Why I'm not quite sure. They could of just run it strait and no issue
Old 07-03-2007, 09:17 AM
DJENSEN9367's Avatar
happened to me a year ago on my 2006, 2500 miles away from home, easy fix once you know
Old 07-03-2007, 09:26 AM
bsj04's Avatar
thanks for the warning i just went out and moved mine!
Old 07-03-2007, 09:59 AM
2003Ram's Avatar
Will have to get out and check mine.......four years, I hope it's not too late.
Old 07-03-2007, 05:59 PM
Shanajustin's Avatar
Thank you very much! Disaster averted. Great tip, sorry about your friends luck.
Old 07-03-2007, 06:17 PM
Outwest's Avatar
Leaving Thursday for Glacier National Park but not before I check on this wire!
Thanks for the heads up...
Old 07-03-2007, 06:33 PM
megafast's Avatar
Great post, thanks for the info!
Old 07-03-2007, 11:59 PM
Joe T's Avatar
Great tip I'll check mine this weekend.
A little off topic, but could I unhook that connector as a theft deterant? I had it unhooked last weekend when installing new shocks and didn't know what it was... It was in my way.
Old 07-04-2007, 09:46 AM
jrussell's Avatar
I love threads like this!!! Thanks for the tip!
I checked mine and the wire wasn't really near the bracket. Either they figured out the problem or I just got lucky with mine. FWIW my truck was manufactured in 06/2006.
Old 07-04-2007, 10:06 AM
Bswope's Avatar
Thanks for the heads up, gonna go check mine out now!
Old 07-04-2007, 11:59 AM
Dieseljunkie's Avatar
Good tip.. I am gonna check mine out today.
Scott
Quick Reply: please read could happen soon.
