Lugs for installing 2nd gen. rims on 1st gen.
Old Apr 23, 2007 | 08:49 AM
Palerider's Avatar
These are the lugs for installing 2nd generation rims on 1st gen trucks. I dont know about the cast rims, but the steel rims do fit. The rims are close on the clearance and the setback is different, but they do fit. Ive had mine on for close to 40k pulling heavy loads with no ill effects. The part number from the MOPAR dealer is, (6034834 NUT .750 22005024). Without these I dont know how you would make the center cap with the Ram stay on or fit.
Attached Thumbnails Lugs for installing 2nd gen. rims on 1st gen.-april-22-2007-018-2-.jpg   Lugs for installing 2nd gen. rims on 1st gen.-april-22-2007-039.jpg
Old Apr 23, 2007 | 04:39 PM
BC847's Avatar
1st Generation Admin
Cool
Thanks for the tip.
Old Apr 24, 2007 | 12:27 AM
GLHS's Avatar
Good tip indeed! I changed all my studs to 9/16 to use the caps.
Old Apr 24, 2007 | 12:49 AM
robwil's Avatar
GLHS,
I replaced all of my 1/2" wheel studs with 9/16" studs as well. I've had the 2nd generation chromed steel wheels on mine for about seven years. I recently got some of the OEM polished aluminum wheels off of a 2nd generation and although they fit great on the rear, they hit the brake caliper and tie-rod end on the front. I was curious how you are running them.
Old Apr 24, 2007 | 10:35 AM
GLHS's Avatar
2" solid steel or aluminum spacers. You can buy them for about $150 for a pair. I would put them all the way around to get the offset correct.
Old Apr 24, 2007 | 02:27 PM
Palerider's Avatar
Ouchy!! Your rims look real nice, but $300 would go quite a ways toward new rims that have the correct offset. New rims from a shop wouldn't have the Ram centers though. I called the dealer for the price of the lugs I listed and their gettin $2.85 each, (list for $5.85). The 2nd generation lugs (9/16) were like $8.50 each (how, i dont know). Their robbing us either way, but they do smile when taking your money, as you limp away.
Old Apr 24, 2007 | 09:52 PM
GLHS's Avatar
A little pricey, yep. Same look, nope. Studs were bought at Napa and/or Carquest for $2 each. I bought the rims with caps and lugs used for $275. I used a 4" holesaw to cut the center for the lockouts. I like the bigger studs to match the higher load capacity of the tires and rims (3500 lbs I think). Half inchers look wimpy.
Old Apr 27, 2007 | 04:05 PM
kiszka6911's Avatar
Okay so what about us guys with the one tons and 5/8-18 lug studs?
Old Jun 29, 2007 | 08:05 AM
Hayseed's Avatar
Talking
If you don't want to go to the dealer for the nuts and don't want to change to the 9/16 stud NAPA part number 6411549 is for the 1/2 stud that is a direct replacement for the Dodge part number above. I paid $1.25 each for them.
Old Jul 1, 2007 | 08:55 AM
Hayseed's Avatar
And the hole size I used is a 4 1/2 inch hole saw.
Old Jul 1, 2007 | 09:13 AM
KB440's Avatar
Anyone have the part numbers for the 9/16" studs to convert it over from 1/2"? Maybe I missed in the thread somewhere.
Old Jul 1, 2007 | 12:41 PM
dpuckett's Avatar
We're just stuck with what we got. Or are we? I have considered changing my front spindles to SRW (if that's even possible), then getting the 2ndGen spacers for the dually wheels. This way, I can have all my wheels match (I have a 99 Dana80 axle in the back) would also make it easier to get aluminum wheels if I ever decide to go that route.
Daniel
Old Jul 1, 2007 | 05:25 PM
ez_lle71's Avatar
I wish i would have known that 2 weeks ago !! haha i payed the dealer 2.85$ a piece!! O well, can't win em all!! haha
I love my 2nd gen chromies on my 92' they look sweet!! ez
[IMG][/IMG]
Old Jul 1, 2007 | 10:23 PM
GLHS's Avatar
Part # 641-2794 at Napa/Balkamp brand.
Part # 610-283 at Carquest/Doorman brand.
I think these were identical if I remember correctly.
Old Apr 11, 2008 | 06:56 PM
schamran's Avatar
3rd Gen Wheels
Does anyone know of any problems with using 3rd gen wheels? Does anyone have any pics?
Thanks.
