Finished [S]tabbing my KDP to death!
Old Mar 25, 2007 | 03:15 PM
dieselfuelonly's Avatar
DTR question asker
Finished [S]tabbing my KDP to death! (LOTS of pics)
Well, I got everything back on the truck today! Started monday afternoon and worked on it a little bit each evening this week and got everything put back together today. I took pictures of everything up to tabbing the KDP, from then on it was just doing stuff in reverse. I will say it was a lot of work... the hardest part was getting the fan and shroud out. Oh and make sure you read each step entirely with the TST kit before you start performing an operation, because sometimes things show up a little later than they should .
And don't be like me and spend 10 minutes trying to put the crank seal in backwards... LOL. That was one of those "make sure you read the whole paragraph first" moments. Enjoy the pics!
Truck before I tore her front end apart
The TST KDP Tabbing Kit
My extremely high tech workbench with some random wrenches I brought down from the toolshed
Under the hood
Disconnecting negative
My cardboard box for punching bolts into and labeling where they went & overflow tank removed
Space left from removing overflow tank
Removed the top radiator hose... and unleashed a flood of antifreeze. Thank god for having cats
Drip... Drip... Drip...
Old Mar 25, 2007 | 03:22 PM
DTR question asker
STUPID WASHER TANK MOVE OUT OF MY WAY
More progress
The next day
My best friend in this project...
You really do need that cardboard between the fan and the radiator...
Out come the bolts
Working it out slowly
Forgot what this pic was for...
Another picture
Old Mar 25, 2007 | 03:25 PM
DTR question asker
And another
Removing the balancer bolts... GOGOGO BIG PIECE OF PIPE!
DARN AUTO! I had to wedge this angle iron into the notch in the balancer to keep the engine from turning over...
Still removing bolts
And its off!
The next day
Progress..
Oil fill removed
An extremely high-tech way of remembering where the gear cover bolts go (GREAT IDEA BOX!) I kinda ran out of space at the top LOL.
Old Mar 25, 2007 | 03:29 PM
DTR question asker
Gear cover bolts removed
Finally inside!
Its moved a bit...
Ramming it back in
DIE! DIE! DIE! KDP "S"TABBED TO DEATH!
The WRONG direction to insert the seal from... LOL!
Ok there we go!
Old Mar 25, 2007 | 03:31 PM
DTR question asker
And we're done! Not to shabby
I love my truck...
Cardboard under to check for leaks... hope to see it bone dry!
Old Mar 25, 2007 | 04:31 PM
ratsun's Avatar
Thumbs up
Great pics, it's a big but comforting job isn't it?
I couldn't help but notice the Canuck flag
Old Mar 25, 2007 | 06:38 PM
Box5's Avatar
lots of pics, lol. Good work, it's satisfying once u get it done isn't it?
Old Mar 25, 2007 | 07:51 PM
barngal6's Avatar
Thanks for the great "documentary" DFO...
I love where the gears are turning as you scroll...
(did I reeeally see that???)
My 98 12v is gonna be here soon, and now i understand how you can't tell if its been done till you're in there...
So if its been "stabbed" , but you can't tell,
is it still possible to remove the pin?
And that looks like a lot more work than I thought...I hate to think
what I might have to pay someone else to do it...
Thanks again for a great view of the job! Now you can rest easy....
Old Mar 25, 2007 | 07:52 PM
Dr. Evil's Avatar
Another disaster averted...
This would make a GREAT Technical "How To" article - Hint, Hint...very good pics as well.
Old Mar 25, 2007 | 08:37 PM
nirion's Avatar
Great pictures. I just picked up my 94 and those will come in handy.
Old Mar 25, 2007 | 09:18 PM
TIMMY22's Avatar
DFO, when you lifted your plastic fan shroud out, did you have a hitchiker (wireloom) connected at the bottom preventing you from pulling it out?
Old Mar 25, 2007 | 09:25 PM
DTR question asker
Barngal-- I'm not quite sure what you mean by you're question, but here is my answer :P
Unless someone has used the jig (which is not reccomended by me anyway because if you hit the pin, then you have to somehow get it back in, which means removing the cover anyway), there really is no way to tell if its been done. So go through the process, tab it, and be done with it. There really is no way the pin could fall out after that.
Dr. Evil-- Thanks for the kind words. I'd be more than happy to write up a little more "in depth" howto, but the TST instructions were really easy to follow. But there are a few things that could be a little clearer, so if you guys who are doing the fix have any questions I might be able to help. Hopefully these pictures will be of help to you all.
Old Mar 25, 2007 | 09:31 PM
DTR question asker
Guess I can't type fast enough
Sorry I didn't answer this in the last post: I had someone tell me that they would do the job for about $200. I don't have that kind of money to spend, so I did it myself. It was nice because it really helped me get to know the insides of my truck a bit better.
Timmy -- No hitchhiker, just getting caught on every other imaginable hose/mount/random piece of plastic/battery cable (REMOVE THAT FROM THE TOP OF THE RADIATOR -- MAKES IT MUCH EASIER)/my hand/getting stuck loop from the shroud getting the fan jammed up against the shroud against the fan against the shroud (LOL). It was a PAIN to get out... don't try it yourself, get someone to help you, I did and it was still very hard to get out, I can't imagine doing it by myself.
Old Mar 25, 2007 | 09:41 PM
TIMMY22's Avatar
Mine had a wire loom with one of those factory cable ties with point/barb setup that snaps into a round hole right in the center of the plastic shroud at the bottom. So, when I was lifting it out, I had some resitance there. Looked underneath and saw the culprit attached to the shroud.
Old Mar 25, 2007 | 09:52 PM
frmll300's Avatar
Thanks for the pics. How long did it take? I'm trying to decide whether to do it myself or pay $300 to have it done including seals .
