Old 11-23-2014, 03:22 AM
  #616
Received 1,637 Likes on 1,112 Posts
Yesterday, I drove to one of the few Pick A Part Boneyards left in NJ and looked around for a few things. Did I find a first gen ? NO. Found some parts for my wife's honda, but I did get to see a few interesting rides.
Someone took the roof off of this gasser. Geesh, I wonder why ?
Then there was this bus.... Supposedly worth a lot of money, but it was really rotted...
Attached Thumbnails What did you do to your Gen 1 today?-1122140918.jpg   What did you do to your Gen 1 today?-1122141041.jpg
Old 11-23-2014, 09:35 AM
  #617
Redtruck-VA's Avatar
There's a really rough bus back behind an abandon shop down the road and I seen there is a 1st gen gasser new addition at a house near by. I'm seeing a lot of 1st gens around recently. There is a really nice gasser I was asking about and was told no way in hell would it be for sale. I asked again a week later and was told again it would never be for sale. lol
Old 11-23-2014, 11:05 AM
  #618
RamGuy84's Avatar
Yeah that is a Camper Van worth money is Tip top shape maybe but that is to far gone .
Old 11-24-2014, 12:57 AM
  #619
Today I put a TorkTek banjo bolt/fuel pressure snubber and a NoShok 0-30 PSI pressure gauge on the truck. Reading 4-5 PSI at idle. At least I know the diaphragm pump is still working. Eventually I'll put a proper fuel pressure gauge in the cab. Probably after I replace the diaphragm pump with a low pressure piston pump.
Old 11-25-2014, 08:52 PM
  #620
Received 1,332 Likes on 862 Posts
Do you have a pic? I need to do this as well....but I already have the piston lift pump.
Old 11-25-2014, 11:40 PM
  #621
No pics yet. I'll take one tomorrow if weather permits (supposed to get 3-6" of snow). The gauge is a back mount 1/8" npt nipple and sticks straight out from the snubber. It works out because you can see it from the side of the truck. You don't have to climb up on the tire to look down at it. The needle on the gauge vibrates a bit but I can live with it. The gauge is made in Germany and was $8 shipped on Fleabay. I mostly wanted to confirm that the lift pump was actually working so I don't fry the injection pump.
Old 11-26-2014, 03:06 PM
  #622
Replaced all three of the U joints, changed the drive shaft support bearing a couple weeks ago. So the driveshaft is now all fresh. Also used all new cap strap bolts.
Old 11-27-2014, 10:02 PM
  #623
Hot Dawg's Avatar
Rescue Mission
Went and rescued my buddy Tim's first gen, the fan hub blew apart and trashed the hub, fan, and rad. Here is a pic of when we got home, Dylan's 92 flatbed auto, my 93 5 speed with trailer, Tim's 92 5 speed on the trailer (460k miles on this rig!), and my "Ol' Janky" 92 5 speed bringing up the rear.
Old 11-28-2014, 09:49 AM
  #624
aicomp's Avatar
Love that line of trucks.
Mike
Old 11-28-2014, 10:11 AM
  #625
It also warms my heart to see a gathering of old iron. Well done...
Old 11-28-2014, 10:34 AM
  #626
DoodleBee's Avatar
Finally installed the new steering shaft - it needs final adjustment and paint. Should be ready to go later today.
cheers
Doug
Old 11-28-2014, 02:32 PM
  #627
Last night while driving home after a movie with my family, the Pyro decided to stop working. I tried hooking and hooking the leads from the Thermocoupler last night, dug under the dash to see if the power and ground were still hooked up...everything looked fine.
So after i came in from the monsoon rains...of course...I dug around on-line and found a PDF file on how to test the early Isspro EV gauge system.
Here is a link for others....
http://www.isspro.com/TROUBLESHOOTIN...leshooting.pdf
Tested everything this morning, and it seemed that the thermocoupler was the culprit. So went down to BD diesel...yup they are 3 minutes from my house... Bought a new T-coupler, and when I got home I tested the new T-coupler and it gave me the exact same readings as my old one.
So the problem clearly was elsewhere. After a little digging and closer inspection I found one of the crimped spade terminals on the wiring off the amplifier had corrosion. Pulled the old spade terminal, cleaned up the wiring and installed and new connector...works like a charm now!!
And just in case someone is testing their T-coupler using the info in that PDF file. The resistance they say you should be getting off the cold T-coupler should be less then 1ohm. My used T-coupler, and the new one both read 3.0 to 3.5 Ohms.
Also the voltage from the amplifier, to the gauge...white and grey wires, should show .8V...mine was .34V and it works fine.
Old 11-28-2014, 10:32 PM
  #628
That is why I solder and shrink sleeve all the terminals I install.
I have had a bunch of similar problems with crimp terminals.
Old 11-28-2014, 10:33 PM
  #629
Mike
X2
Old 12-01-2014, 06:39 PM
  #630
Got my sandbag racks back from the powder coating company I use.
Can't wait till we get some snow to see how well they work out.
Quick Reply: What did you do to your Gen 1 today?
