reverse light switch location ?
Old Feb 18, 2008 | 09:50 PM
redz's Avatar
Hey all Redz here,
looking to replace my reverse switch on my tranny, can any one tell me where abouts on the tranny (top-side-bott) I can find it? any tricks?/treats?
Thanks ,Redz
BLACK 2001-2500 5 speed QC LB,FASS,dss,spanking new inj pump,fuel press and boost gauge-------- REVERSE LIGHTS OUT!--------
Old Feb 18, 2008 | 11:57 PM
redz's Avatar
Unhappy reverse LIght ??????????????? no one ???????????
How can nobody know this one ?! somebody ?? OK how about the beginning rev lights stoped working, fues is good ,one extra light pigtailed up to the 7 pin----NO LIGHTS---- so must be the reverse light switch ,that is located exactly_____ _____ _______ ______ _ on the 5 speed tranny.
Please fill in the blank
Thanks Redz
Old Feb 19, 2008 | 07:42 AM
99turborock's Avatar
hay redz, the reverse switch on the nv4500 is located on driverside very top of tranny. You will NOT be able ot see it, I takes a long socket I forget the size (maybe 19mm deep socket) You can buy for $12 at http://quad4x4.com/ I spent $50 at napa. Make sure your check your fuse. good luck
Old Feb 19, 2008 | 09:02 PM
redz's Avatar
Smile reverse light switch
Thank you very much 99turborock, I knew some one had to know this info
Old Jul 30, 2008 | 10:54 AM
Buckskin03's Avatar
Thanks for putting the location of this. I was looking for it and could not find it as well. Man they could have made it a little easier to get to.
Old Jul 30, 2008 | 04:00 PM
Dave Miller's Avatar
It's the only thing on the transmission with wires attached. Before you R & R, pull the connector off the switch and "jump" the two conductors in the connector (key on). If the jumper causes the lamps to light (key on), the switch is the problem. If they don't light, check elsewhere. I believe the connector was 22 MM deep socket.
thrashingcows
Dec 14, 2010 05:34 PM
99turborock
13
Apr 12, 2010 07:58 PM
JPR Ram
Mar 25, 2009 05:46 PM
Lama
Dec 10, 2006 11:34 AM
59FORD
Apr 7, 2006 12:28 AM
