ole shakey upgrade
Old 11-26-2010, 06:30 PM
Moparbubba's Avatar
ole shakey upgrade
hey yall im new here i no my profile says 07 but neway.. like my signature says i got an 92 d250 with some work done im planning on cooler tubz airdog lift pump 60/16mm turbo upgrade sdx 5x14 injectors and a powertrax lockrite for the dana70 does that sound like a gd set up? and is that m&h dynamic timing advance a gd upgrade? and lastly has neone tried denny t`s cnc afc delete it looks gd is he makin em to sell?
Old 11-26-2010, 06:39 PM
Welcome. I'm about an hour north of you in Jersey...maybe hour and 15 mins.
the dynamic timing advance is a great thing because you'll keep your low end power but gain the top end power of advanced timing.....you lose low end power when you advance the timing normally.
I wouldn't recommend having no AFC for the street....that'd be a smokey mess.
all your plans sound good but you didn't say what trans you have....if you have an auto you're going to need a good torque converter and if you have a 5spd youre going to need a clutch to hold the power. after injectors you'll blow right through the clutch.
The lockrite is a great idea. i know a guy with 90 cummins 2wd with a lockrite and it's downright nasty
Old 11-26-2010, 06:58 PM
Moparbubba's Avatar
shes an a518 im planning on a rebulid, shift kit and a gorearend converter.
Old 11-26-2010, 07:12 PM
Onemoparnut's Avatar
Sounds like a good plan so far.
Old 11-27-2010, 02:03 PM
Moparbubba's Avatar
btw with what ive got done and planned (im ordering the timing advance next week) what should i expect on the dyno and 1/4 mile et (i know the trans is a big factor) neone care to guess?
Old 11-27-2010, 02:10 PM
mid to low 15's in the 1/4 , all depends on traction.
once you get injectors and more pump work and build the trans and get a posi you'll be runnign 13's
Old 11-27-2010, 02:52 PM
What he said!!!
Old 12-13-2010, 09:44 PM
Moparbubba's Avatar
ive had a slight set back in upgrading ole shakey the water pump locked up solid on the way home friday nite from work and i managed to idle her home thankful it was freezing out and it didnt overheat her shreaded the belt so after autozone water pump and belt shes running great seems like the old water pump must have been going for a while and robbing power cause she seems to have more. a little weird tho the weep hole never leaked and it didnt have play when i checked it last... funny part is it said made in england on it... so now after christmas m&h timing spacer.
Old 12-14-2010, 02:35 PM
dieselJon's Avatar
Bubba, I have pretty much the same as you right now except I have POD equivalents and a 18cm housing. I do 16.10x in the 1/4 and thats with a TIRED torque converter.
Old 12-14-2010, 06:28 PM
Moparbubba's Avatar
16ish is what i was thinking with it bin a club cab and with a loose converter.
after reading on here im thinking of doing a low pressure piston lift pump instead of the airdog for 2 reasons 1. the motor stays mechanical (ive driven with no alt or battery power twice now nice to still be mobile even when broken down...) and 2 it seems to be cheaper and flow enough for the 300hp i wanta shoot for. that sound like a gd idea to yalls?
Old 12-14-2010, 06:44 PM
Rick 12v CTD's Avatar
it's what I did and have no regrets. Plus I did it for less than half the price of the airdog or equivalent
Old 12-19-2010, 02:39 PM
Moparbubba's Avatar
heres some vids of ole shakey
Old 12-24-2010, 03:23 PM
Moparbubba's Avatar
got myself an outerwears prefilter for the s&b filter on the dnr intake hopefully it keeps some of the big stuff and chicken feathers outa that expensive filter...ole shakey upgrade-162693_1748156352763_1504450447_31813769_4485135_n.jpg
Old 01-26-2011, 03:55 PM
Moparbubba's Avatar
still on the "waiting list" for my timing spacer from m&h been almost a month. neone else have wait a little while?
Old 02-23-2011, 04:14 PM
Moparbubba's Avatar
gd news m&h is sending my timing spacer. had to wait awhile but thats alright. Has neone used one of these yet ive got mine bottomed out and no runaway
89-93 Dodge 5.9L Cummins Extra Long Fuel Adjustment Screw from Pure Diesel Power
Quick Reply: ole shakey upgrade
