My 24v cummins ve pump conversion
Old 10-28-2012, 03:38 PM
metallic88's Avatar
so my second vp44 died and i was always thinking about ppumping my truck but my friend has a 12v with it and it isn't as daily driver as i wanted it, so i decided to do the old 1992 ve pump with dynamic timing.
http://s635.beta.photobucket.com/use...tml?sort=3&o=5
removed the crappy vp44
http://s635.beta.photobucket.com/use...tml?sort=3&o=4
no more home for the vp44 what a sweet sight
http://s635.beta.photobucket.com/use...tml?sort=3&o=3
new home for the ve pump
http://s635.beta.photobucket.com/use...tml?sort=3&o=6
1992 non inter cooled ve pump arrived
http://s635.beta.photobucket.com/use...tml?sort=3&o=1
ve pump installed, I timed it on the letter c of the gear, and installed 3200 rpm spring
first run of the ve
http://www.youtube.com/watch?v=WxYIFanmSPs
my moded dv holders were leaking so i finally found a place that made custom lines and there on there way
so far the parts list needed
89-93 dodge ve pump preferably non intercooled
89-93 dodge ve pump gear
89-93 dodge timing cover
89-93 dodge overflow valve
89-93 fuel line
boost line kit
throttle linkage
imo 3200 rpm spring
custom injector lines i got mine from here http://ktperformance.net/
and then lol one wire for the shut off solenoid
Old 10-29-2012, 08:03 PM
iwhitne's Avatar
lookin good! keep us posted!
Old 10-31-2012, 10:05 PM
metallic88's Avatar
vid with the new lines
http://www.youtube.com/watch?v=kxiZ-zUmpGc
Old 11-03-2012, 11:49 PM
metallic88's Avatar
close to being done
http://www.youtube.com/watch?v=17rpNt2dzVI
all finished up and its sweet
http://www.youtube.com/watch?v=oF9lFbAbqqc
Old 11-06-2012, 12:36 PM
6cylinders's Avatar
Does this swap throw any codes, CEL's?
Nice work and thanks for sharing!
Might be the answer I've been looking for, getting tired of the VP44 sword
hanging over my head all the time. Time to quit staring at the FP gauge
and just drive
Old 11-06-2012, 09:23 PM
metallic88's Avatar
and just drive
yes the cel is on(and has been for awhile due to the crappy vp44 lol), and im not sure what codes i need to hook up my scanner i guess but id think it would just be the vp44 missing codes, other than that everything else works great since i have the vacuum cruse control. thx i just hooked it up and there p1693 and p1689 are the only codes
Old 12-30-2012, 06:30 PM
taggmann's Avatar
cool I thought about doing this once too. how is it working? getting rid of the vp seemed like a good idea and I didn't want to stretch to the p pump conversion
Old 12-30-2012, 07:43 PM
metallic88's Avatar
its working great im getting 20mpg, and it tows great.
Old 12-30-2012, 10:13 PM
rebal's Avatar
does it start like the old 1st gens ,first cylinder up and its running?
Old 12-31-2012, 06:41 AM
metallic88's Avatar
yes that's the best part it fires quick hot or cold and even with one battery if you want
Old 01-01-2013, 05:27 PM
TOM R's Avatar
so all in all if you had to buy all the parts needed to do the conversion what would it cost?
Old 01-01-2013, 07:46 PM
metallic88's Avatar
it cost me $1100 for all the parts including the ve pump
Old 01-01-2013, 11:11 PM
Tate's Avatar
The only thing that you would be stretching farther would be the p-pump lines, everything else is pretty much the same idea, just a few different parts.
I'm biased to the p-pump, but I always thought that VE swap would be a good fix for the VP. Good to see someone do it.
Old 01-01-2013, 11:26 PM
metallic88's Avatar
for what i do with it and as a dd its great, but if i towed alot then i would have p-pumped it.
Old 01-04-2013, 08:31 PM
TOM R's Avatar
IS THAT 1100 WITH NEW PARTS OR USED? what is a p pump?
Quick Reply: My 24v cummins ve pump conversion
