help truck dies alot
Old May 12, 2013 | 03:38 PM
kauai_life_808's Avatar
"hi i have a 1998 dodge ram 2500 with a 5.9 cummins and when i start it up and put it in gear it has a rouph idle and if i try to turn the steering wheel it dies and also if i just tap the throttle it dies also. what could my problem be?"
Old May 12, 2013 | 03:52 PM
Recon2531's Avatar
I would start with checking lift pump pressure. Start eliminating what you can before throwing parts at it. Does it start easily? Are your batteries/charging system working properly. It could be any number of things.
Old May 12, 2013 | 04:48 PM
checking
how do i go about checking the lift pump pressure?
Old May 15, 2013 | 11:52 PM
taken5875's Avatar
Mind had similar issues. Turned out my injectors were getting out of spec. I think they were just a little off but after I put 100hp tips on them it caused the problem that you are having.
Old May 17, 2013 | 04:41 PM
Recon2531's Avatar
Sorry, I thought someone else may jump in and splain it. Simply put, there is a shrader valve on the fuel supply line to the injection pump. It's on the side of the I.P. If your looking at the motor standing by the drivers side front tire, it's right in front of you. Hook fuel pressure gauge to shrader port and "bump" key. Pump should run for 20-30 seconds and you should see about 12psi, hopefully.
kauai_life_808
May 12, 2013 05:53 AM
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
crash4wd
Dec 17, 2007 08:48 PM
j
Apr 2, 2007 03:37 PM
