Disadvantages of Mystery Switch
Old Apr 7, 2007 | 06:51 PM
97DodgeRam's Avatar
What are the disadventages of having a lock-up switch? The local tranny guy said that taking the fusing out and jump wiring it will cause the tranny to go into limp mode. He could then find a reason to void my warranty. Is there another way to set up a lock-up switch? I really like having control of the lock-up but I don't want to void my warranty. Thanks.
Old Apr 7, 2007 | 07:31 PM
AlpineRAM's Avatar
With the 98.5 and up it the lockup switch will set a code (I don't know whether it will for the 12V) because the PCM sees the jumper cable instead of the relay and thinks the relay is bad.
Since a lockup switch does place a much higher load on the tranny (shifting locked, low rpm- high torque situations) I do understand your tranny guy for not wanting you to use it.
AlpineRAM
(PS-I've got a lockup switch and like it- but if I break my tranny by abusing it I know that there's no warranty...)
Old Apr 8, 2007 | 11:13 AM
infidel's Avatar
On your 12 valve about the only disadvantage I can see is coming to a stop with it locked up many times. If you did this it seems anyone should have the right to void your warranty.
Old Apr 8, 2007 | 04:21 PM
97DodgeRam's Avatar
The tranny guy said that w/o the fuse, it would go into limp mode. I had it on my tranny before I rebuilt it, and it never caused a problem. I'm thinking about putting it back on w/o him knowing because i love the extra braking and hate how the TC disengages when you let off of the pedal. Thanks.
Old Apr 8, 2007 | 08:50 PM
74dart's Avatar
There are a few after market tranny control systems liek the ATS commander. It will unlock it when the truck gets to 18mph to keep from stalling it out.
Old Apr 8, 2007 | 09:25 PM
Fueling around's Avatar
The other problem is low rpm high throttle. The PCM will usually unlock to save the converter clutch and/or the tranny clutche(s)
Old Apr 9, 2007 | 06:44 AM
j-fox's Avatar
A few guys have broken the input shaft and or the flex plate too!!!
The fluid coupling during shifts is to cushion the hard parts.
With my set-up, normal driving is fine unlocked. Locked is abuse.
Old Apr 9, 2007 | 10:09 AM
XLR8R's Avatar
I wired a 3-position mystery switch on my '98 to control both the OD & TC lockup solenoids. That way, the truck doesn't wander in and out of OD at ~45mph, and the truck drives like a manual on the interstate.
Old Apr 9, 2007 | 10:14 AM
belgianmagic's Avatar
Ok , I have an 05 ...How do I do that>?? can you pm me with the info Please, thanks Flip
Old Apr 9, 2007 | 11:12 AM
XLR8R's Avatar
On an auto '05 (mine is a G56), the tranny solenoids should operate off of a switched ground circuit - so I'd try switching the YL/LB wire to the torque converter solenoid as a start... you really ought to check the schematics to make sure though!
Old Apr 9, 2007 | 11:25 AM
I don't understand what that means...sorry
Old Apr 9, 2007 | 12:14 PM
smkn97s's Avatar
Becarful if you have stock shafts I broke my input using a lock up switch
Old Apr 9, 2007 | 01:52 PM
ok, don't need that headache , thanks
Old Apr 9, 2007 | 02:14 PM
gunracer1's Avatar
mines still alive at 262k and a little over 500 rwhp. but i am lucky i guess.
Old Apr 9, 2007 | 02:35 PM
CSAGrey1's Avatar
I have yet to find any disadvantages with mine. Love it and won't get rid of it. I do however have the billet input.......
