Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
C-15 Caterpillar Injector issues...
Old 08-08-2011, 05:20 PM
Hillbilly_Deluxe's Avatar
So here's the deal... Did the first rebuild on my C-15 (6NZ) recentley at 800 000 Miles, and 35 000 hours.. Worked great , just was pressurizing the coolant (due to a blown head gasket, which was due to a cracked sleeve) Replaced everything but the injectors water pump and oil pump. I have only put about 500 kms (200 or so miles) on it since getting it back, but now it seems to have a little bit of a "flutter" in it. bThought the vales may have seated so I had them reset with no change. Before the rebuild I use to be able to get 40-42lbs of boost easily, now I can only get 30-34 and it takes a little longer to spool up. Any ideas on what the issue would be? Im thinking sticking injectors, but the cut out test didnt really seem to reveal much.
Old 08-10-2011, 08:51 PM
PoorMansCat's Avatar
Do you have ET??? Attempt to do a timing calibration procedure.
What all parts were changed and did you use Cat parts or aftermarket.
pilikua
03-23-2006 09:07 PM
jlells01
03-20-2005 03:52 PM
BBWD
08-28-2004 04:12 PM
Quick Reply: C-15 Caterpillar Injector issues...
