bypass fuel heater
Old Jan 23, 2009 | 04:41 PM
patpat paul's Avatar
bypass fuel heater
can anyone help me bypass fuel heater on a 98 12valve its leaking air and confused on how to do it pics would be nice hahahaha or however just need some help cant go anywhere and its friday
Old Jan 23, 2009 | 06:45 PM
infidel's Avatar
Picture should explain it all, just remove the heater section, shorten the inner shaft and put it back together.
Old Jan 23, 2009 | 06:55 PM
thanx
thanx again for you help man i will try and rig sumpn up
Old Jan 23, 2009 | 07:30 PM
sorry
i really need to take that part completly out of the pic i think the fuel heater is letting air into my fuel any other ideas???
Old Jan 23, 2009 | 08:48 PM
GAmes's Avatar
Remove the prefilter bowl. I think it is a 15 mm socket. Disconnect the wires. Then take the heater assy out using an allen head wrench. The filter bowl will then screw into the hole that held the allen head bolt. You will get a cupfull or so out of the prefilter so be careful of that when you remove it.
Old Jan 24, 2009 | 02:15 PM
infidel's Avatar
I use two socket extensions and a swivel joint when removing the bowl.
Otherwise it's a diesel bath.
TXTad
Nov 25, 2012 07:58 PM
Big Smoky
Sep 24, 2008 11:54 AM
Exekiel69
Jul 6, 2008 10:10 AM
75bronco
Jan 22, 2008 09:31 PM
taildragger
Dec 4, 2006 10:00 AM
