To you guys with Quadzilla xzt+
Old 02-19-2008, 02:53 PM
Norway's Avatar
Hello!
I run a Hypertech with a j-hook and boostfooler today,
(as you can se in my sig.).
I am thinking about moving up to a xzt+.
Will this be a noticeable uppgrade in power?
Anyone who has made a simular uppgrade??
Kjetil
Old 02-19-2008, 02:56 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
YES, you will notice a power difference, especially if you down load the aggresive tune. I switched from a Banks Ottimind to the XZT+. I feel the XZT+ is a better unit and worth every penny you spend getting it.
Old 02-19-2008, 03:06 PM
Krob's Avatar
Ive had an EZ and now the XZT+ and hands down i like the XZT+ better. You also get a high idle and a fuel milage setting. Not to mention Quadzilla has awsome costomer service.
Old 02-19-2008, 03:12 PM
bullboy85's Avatar
im the same as robins, i went from a EZ to the XZT+, and couldnt be happyer and quad doesnt seem to be done yet. one of my buddys had a hypertech and it never compaired to my XZT+ even before i loaded the aggresice tune.
Old 02-19-2008, 04:31 PM
Obben's Avatar
I have a XZT+ for sale as soon as I get the adrenaline shipped and installed.
The good thing is that its already overseas(Sweden).. the bad thing is it is for a 02, but as far as I know the only difference is the adapters from the harness to the 02 MAP-sensor contacts.
I think the contacts on the harness is compatible with the 01.... maybe someone can chime in and correct me if it isn´t so.
PM me for info.
Eller på Svensk... jag har en XZT+ till salu så fort jag får min adrenaline. bör dyka upp snart... men du kan ju PMa så slipper jänkarna läsa Svensk/Norsk...
Old 02-19-2008, 04:51 PM
hink's Avatar
It will work on an 01 with a MAP sensor adapter.
Old 02-19-2008, 05:07 PM
Obben's Avatar
I think it´s the reverse... It will work on the 01 without the adptors.
The 02 version comes with adaptors to fit the MAP-sensor...
Old 02-19-2008, 05:57 PM
hink's Avatar
That could be right, it's been awhile since I had my XZT+.
Old 02-19-2008, 06:08 PM
Purplezr2's Avatar
Anyone one have the XZT+ with recon gauges, anyone with the fuel pressure gauge, were they hard to install, how do they like the like unit for the gauges.
Old 02-19-2008, 06:20 PM
JPR Ram's Avatar
I was running the XZT+ stacked on a Quadzilla Xzillaraider and a Recon Digital gauge that monitors the EGT's, boost and tranny temp. I didn't have the fule pressure set up. The Recon is a really good, cost efficiant, little unit. It's easy to read, easy to install and very easy to use. But I like being able to glace once and see all of my parameters. So I just switched to Isspro analog gauges. I didn't want the Recon to sit around and collect dust, so it's now in the DTR classifieds.
Old 02-20-2008, 02:05 PM
Norway's Avatar
Thanks for your feedback.
Kjetil
Old 04-06-2008, 01:39 PM
high bid's Avatar
ok, I'm in the middle of the XZT+ install and the plugs don't seem to match up? The data link is triangular and the map plug is also? Do I need to get adapters from Quad? They weren't in the box...or does anyone have them and are not using them? Any help would be appreciated. Taking a break right now but not sure what to think.
Old 04-06-2008, 04:43 PM
bullboy85's Avatar
99 shouldnt need any adapters, mine didnt.
Old 04-06-2008, 06:23 PM
high bid's Avatar
ok, I'm guessing I haven't found the right plugs then, as it says to plug into the map and data link plugs....right? The wire harness has one small plug for the incab switch, one flat 3 prong plug and two plugs for the map sensor.
Have I missed something or do I have the wrong harness? Is there a # on your harness I could compare? Thanks.
Old 04-06-2008, 06:32 PM
JPR Ram's Avatar
That sounds right. Have you found your Map sensor on the motor yet?
Quick Reply: To you guys with Quadzilla xzt+
