To you guys with Quadzilla xzt+
Hello!
I run a Hypertech with a j-hook and boostfooler today, (as you can se in my sig.). I am thinking about moving up to a xzt+. Will this be a noticeable uppgrade in power? Anyone who has made a simular uppgrade?? Kjetil |
YES, you will notice a power difference, especially if you down load the aggresive tune. I switched from a Banks Ottimind to the XZT+. I feel the XZT+ is a better unit and worth every penny you spend getting it.
Ive had an EZ and now the XZT+ and hands down i like the XZT+ better. You also get a high idle and a fuel milage setting. Not to mention Quadzilla has awsome costomer service.
im the same as robins, i went from a EZ to the XZT+, and couldnt be happyer and quad doesnt seem to be done yet. one of my buddys had a hypertech and it never compaired to my XZT+ even before i loaded the aggresice tune.
I have a XZT+ for sale as soon as I get the adrenaline shipped and installed.
The good thing is that its already overseas(Sweden).. the bad thing is it is for a 02, but as far as I know the only difference is the adapters from the harness to the 02 MAP-sensor contacts. I think the contacts on the harness is compatible with the 01.... maybe someone can chime in and correct me if it isn´t so. PM me for info. Eller på Svensk... jag har en XZT+ till salu så fort jag får min adrenaline. bör dyka upp snart... men du kan ju PMa så slipper jänkarna läsa Svensk/Norsk... [laugh] |
It will work on an 01 with a MAP sensor adapter.
I think it´s the reverse... It will work on the 01 without the adptors.
The 02 version comes with adaptors to fit the MAP-sensor... |
That could be right, it's been awhile since I had my XZT+.
Anyone one have the XZT+ with recon gauges, anyone with the fuel pressure gauge, were they hard to install, how do they like the like unit for the gauges.
Originally Posted by Purplezr2
(Post 1955112)
Thanks for your feedback.
Kjetil |
ok, I'm in the middle of the XZT+ install and the plugs don't seem to match up? The data link is triangular and the map plug is also? Do I need to get adapters from Quad? They weren't in the box...or does anyone have them and are not using them? Any help would be appreciated. Taking a break right now but not sure what to think.[yuk]
99 shouldnt need any adapters, mine didnt.
ok, I'm guessing I haven't found the right plugs then, as it says to plug into the map and data link plugs....right? The wire harness has one small plug for the incab switch, one flat 3 prong plug and two plugs for the map sensor.
Have I missed something or do I have the wrong harness? Is there a # on your harness I could compare? Thanks. |
That sounds right. Have you found your Map sensor on the motor yet?
