X2 RACE EGT's
Old 01-26-2008, 08:45 PM
LFD2037's Avatar
X2 RACE EGT's
I just upgraded my X2 Standard to Race & I can't get to 60mph WOT w/out hitting 1450 degrees. Boost is working good @ about 38 lbs.. With the STD version I would only get to 1300 @ 80mph w/44 lbs. of boost. Do my Race #'s match what ya'll are seeing w/yours? If so, besides a bigger turbo, what can I do to get the EGT's down? Thanks!
Old 01-26-2008, 08:55 PM
TNLoneWolf's Avatar
Wow, I just bought a race version. I hope that's not the way my 05 truck reacts, I'm stacking mine with a Smarty. This could be bad! I've downloaded the stack MPG version on mine. The version that has the PL1 switch set to the Max Mileage program. I guess I'll just have to wait and see.
Are you running empty and what setting are you on?
Old 01-26-2008, 09:04 PM
qzilla's Avatar
If you stay at WOT you are going to stabilize somewhere around that temperature. 1450 is not all that hot for the 600 series trucks especially considering the power you are making. As boost stays up the load at higher rpms will be less and the temp will stabilize if not drop at some point.
Old 01-26-2008, 09:12 PM
TNLoneWolf's Avatar
Thanks Qzilla, THAT'S WHY I BOUGHT MINE! He's always on top of everthing! And the products ain't bad either.
QWKSLVRZ06
11-26-2011 02:59 AM
BigBully
03-18-2009 10:01 PM
BigJohnston
02-07-2008 06:14 AM
CTDowerTN
06-19-2007 09:00 AM
LinearX
06-14-2005 04:48 PM
Quick Reply: X2 RACE EGT's
