Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
WVO compatible FP sending unit
Old Sep 27, 2006 | 11:01 PM
CSAGrey1's Avatar
Anyone know where to get an electronic fuel pressure sending unit that is WVO compatible? I replaced my lift pump after seeing low pressures on the new gauges and it doesn't seem to have helped. I plan to try a mechanical gauge this weekend to make sure that it is the gauge and not another bad LP but I am thinking that the sending unit was not compatible. And just a note but I see the same pressures with WVO and #2 alike so it isn't the difference between the two.
Old Sep 28, 2006 | 07:30 PM
infidel's Avatar
I would think any sender would be compatible with WVO.
Actually diesel fuel is incompatible with more materials than most other fluids.
Here's chart relating to o-ring materials but many of the same materials are used for hose, sender diaphragms, etc.
http://www.efunda.com/designstandard...C=Diesel%20Oil
You might look though the chart, I'll bet it lists materials compatible with veggie oil, I know it lists the ones compatible with beer.
Personally if I found the sender to be shot I'd just replace the FP set up with a mechanical gauge.
Much more reliable.
Old Sep 29, 2006 | 12:24 AM
CSAGrey1's Avatar
Got another sending unit this morn but won't be putting it in until I get the tranny rebuild since I lost 1 and 4 this morn. It's toast.
Dieseldude4x4
Oct 24, 2005 09:12 AM
figure_9_pro
Nov 11, 2002 08:53 PM
SammyBuca
Nov 4, 2002 09:17 AM
JASON T.
Oct 20, 2002 01:53 PM
