Wondering about the stereo in my truck
Old 12-07-2008, 06:17 PM
boney's Avatar
Seems like to topic of the stock stereo is coming up a lot so I'll chime in with my issues and questions.
First, I have the tweeters on the pillar (98.5 24v quad cab), does that mean I have the infinity system?
The problem is that it won't read CDs. None of 'em. It just says "err" when I put 'em in the slot. Is this common? Is there an easy fix? Should I just bite the bullett and install an aftermarket? If so, who makes a 1.5 din to fit?
Old 12-07-2008, 06:31 PM
infidel's Avatar
I did and I'm happy I did.
Bought a brand new Sony eXplode off eBay for $89 and a wiring harness for $10.
Took 20 minutes to install, has twice the wattage as the Infinity, plays mp3s and even has an aux jack for my iPod.
Old 12-07-2008, 06:38 PM
TallTom's Avatar
I have had that problem before , I purchased a can on air from office depot and sprayed it into the cd slot. I think the eye is just covered with dust and can't see the cd.
It solved my problem. I am sure you will have people tell you not to do it that it may mess something up but what do you have to lose. You are considering replacing it anyway.
TallTom
Old 12-08-2008, 11:52 AM
SIXSLUG's Avatar
I have the stock infinity system and the speakers are garbage but the deck still works fine. Try the blow out as described above if it already doesn't work.
Kurt
Old 12-08-2008, 04:55 PM
ado2b1's Avatar
My truck did that with any burned CD and has begun to do it to factory created CD's. I have been ejecting the CD, rotating it a few degrees and reinserting it. Usually works after the first couple of tries. But if you need to get by, that might work for you too. I figure I'm burning out the eject mechanism at four or five times normal, but I will eventually replace with aftermarket. I just wish there was a din-and-a-half that wasn't ugly or way too expensive so I could get an exact fit aftermarket.
Old 12-21-2008, 05:02 PM
cannonballtn's Avatar
I have pioneer din and a half in my truck . Looks and fit is perfect. Sounds good too.Think i paid about $200 for it at Crutchfield.
Old 12-21-2008, 08:34 PM
boney's Avatar
Spraying it out with the can-o-air did the trick. It doesn't read the CDR's that I make with my computer though. It must be "one of those" that doesn't.
06dodgedrw
05-17-2011 08:10 AM
chumstone
12-07-2007 12:22 AM
Grand Geek
04-04-2004 01:06 PM
George C
01-10-2003 07:28 AM
Mopar_Mudder
11-11-2002 10:40 PM
Quick Reply: Wondering about the stereo in my truck
