Witch way doe's it go
Old 11-09-2003, 09:50 AM
Dieselbuilder's Avatar
Looking to install water filter and wanting to know if the water line going from the water pump to the heater core is push or sucking?
Old 11-10-2003, 08:11 AM
Re:Witch way doe's it go
Man, I didn't think this was such a had Q" to answer guess will have to do it the old way and get wet? I thought some one out there would know the direction of flow of the water pump!
Old 11-10-2003, 08:42 AM
jfpointer's Avatar
I'd have to print this out to tell, since the context is pretty small:
Old 11-10-2003, 09:31 AM
AaronT's Avatar
Question: why do you think you need a water filter for the heater?
Old 11-10-2003, 09:43 AM
P Kennedy's Avatar
Water or coolant filters are used on commercial diesels to keep the impurities from accumulating in the block and rad core. They also come with DCA additives to maintain PH balance and prevent corrosion and scale build ups, allows for longer coolant life and other components down line like the heater core. As the little Cummins is rated for a 350k to 500k life before rebuild a water filter with additives could be beneficial for component life to match this milage. PK
Old 11-10-2003, 12:51 PM
Thank you, P Kennedy you took the words right out of my mouth!!!!!!!!!!!
Old 11-10-2003, 03:13 PM
Scubasteve's Avatar
An easy way to tell what hose does what is to turn the heat on and place the fan on high. After it has circulated for a minute check which hose is hot and which hose is warm.
Hot hose goes to the heater core
Warm hose comes from the heater core.
Works like a charm
Good Luck
Jason
Old 11-11-2003, 06:51 PM
AaronT's Avatar
Thanks. I have not seen 1 yet with a coolant filter.
kyle_truck_pull
02-21-2008 12:15 PM
bobva
11-22-2006 01:33 PM
puffmagicdiesel
03-21-2006 02:40 PM
tinman1911
05-27-2005 11:06 PM
Quick Reply: Witch way doe's it go
