wire tapped problems
Old 03-27-2004, 06:04 PM
mooseman's Avatar
Unhappy wire tapped problems
tapped the pump wire yesterday. truck ran great yesterday. today it cuts in and out when you stomp on it (on level 5). ive got 2 codes showing up p1693 and p0253. what does all this mean. can nebody help please.
thanks, mooseman
Old 03-27-2004, 06:24 PM
Trashdawg5050's Avatar
What color is the smoke when it cuts in and out
Old 03-27-2004, 07:42 PM
MnTom's Avatar
Check here for what the codes mean: http://www.obdii.com/codes.html
Tom
Old 03-27-2004, 08:08 PM
mooseman's Avatar
thanks guys for your replys. there is no smoke when it cuts in and out. since the wire was tapped there hasnt been much smoke on 5 set to highest response setting. could the wrong wire be tapped?
thanks, mooseman
Old 03-27-2004, 08:24 PM
billg's Avatar
The P-1693 is a code to let you know a code was set in one of the other computers. It is known as a companion code.
P-0253---- Fuel Injection Pump Fuel Valve Open Circuit---Problem sensed with fuel circuit internal to fuel injection pump.
What kind of pressures are you seeing at the lift pump? The most important would be the pressure during WOT. It needs not to be less than 8psi.
Old 03-27-2004, 08:55 PM
mooseman's Avatar
i dont have a fp gauge yet. i hope its not a pump. the darn thing ran great till the wire was tapped.
thanks, mooseman
Old 03-28-2004, 10:29 AM
dieselman24's Avatar
I really hate to say it but it sounds like you are buying a new pump....
Old 03-28-2004, 10:53 AM
Racer57's Avatar
P0216 is the kiss of death code for a VP44. Check all connections, dialectric grease em, and check ground. Also, did you go to fuse #17?
It is possible that you tapped the wrong pump wire, that is why I used a Blue Chip cover. HTH
Old 03-28-2004, 01:31 PM
mooseman's Avatar
i did use fuse 17 for power. does anyone know of a picture that points to the pump wire to be tapped. i had it done at the shop where i got my trans done. maybe he did tap the wrong wire. i cant seem to find a good pic. to double check the install.
thanks, no power mooseman in utah!
Old 03-28-2004, 09:09 PM
99 cummins's Avatar
I already have my Comp box installed with the wire pierced but am skeptical as to if I am getting the performance that I should. Where can I get this Blue Chip Cover from. I used to get a considerable amount of smoke from my truck with the box, but then I threw away the stock lift pump and Banjo bolts and installed a high pressure fuel system, now I don't get sqwuat for smoke from it. The pressure guage never goes below 12 pounds no matter what I do.
Old 03-30-2004, 07:48 PM
99 cummins's Avatar
Anybody out there tell me where to find this Blue Chip Cover mentioned in the previous post.
Old 03-30-2004, 08:20 PM
billg's Avatar
It will be the 3rd item down.
http://www.bluechipdiesel.com/search...btnSearch.y=11
Old 03-30-2004, 11:37 PM
99 cummins's Avatar
Hey Billg, thanks for the lead. Can you tell me more about how it works? Either the description is kinda vague on it or I'm just kind of a rock, but either way.
Old 03-31-2004, 02:31 AM
BigBlue's Avatar
It punctures the plastic over the wire UNDERNEATH the cover.
Old 03-31-2004, 02:33 PM
DynamicalyUnstable's Avatar
So is this a way to make it so that the dealer cannot detect any tampering with the wire? I am going to try to get mine warrantied but would love a way to pierce the wire on the new one without actually doing it!
Quick Reply: wire tapped problems
