Winter Fuel Mileage
Old Dec 7, 2005 | 09:26 AM
98ISURAM's Avatar
Winter Fuel Mileage
Just curious if it is normal for CTD to slip a little on fuel mileage during the winter months when it gets cold? If so what is the reason and is there anyway to correct that problem. Thanks a lot.
Old Dec 7, 2005 | 09:35 AM
Herrin811's Avatar
I got 13.7 last tank, only 1400 miles on the truck so far...Just did the tone ring and BHAF, and was hoping to see 15...But now temps are in the teens, and I've dropped to 12.5 overhead due to morning warm-up
Old Dec 7, 2005 | 06:24 PM
phox_mulder's Avatar
Many factors come into play.
Winter Fuel (less energy than straight #2),
colder fuel (thicker),
colder engine (much fuel wasted out the tailpipe till it gets up to temp),
more idling (to get it warmed up).
phox
Old Dec 7, 2005 | 06:54 PM
Mopar1973man's Avatar
Best thing you can do is...
  • Put your truck in a garage. (even if it's not heated)
  • Plug in the block heater.
  • Use your jake to warm the engine in the morning. (EGT 400-450*F)
  • Allow it to get up off the 140*F mark before taking off.
I'm still getting about 16-17 MPG roughly even with the cold weather... 0-10*F in the morning...
Just my 2 cents to help!
Old Dec 7, 2005 | 07:28 PM
P.J's Avatar
P.J
I have lost aprox. 2 mpgs, It's hard to tell though because I did my exhaust and BHAF a few weeks ago, so I have been into hearing the truck run a bit more latley.
Seriously though, what Phox said. I lost about the same miles per last winter.
Old Dec 8, 2005 | 05:56 AM
VADSLRAM's Avatar
completely normal
cold fluids take more energy to move around and you have to spend more time to warm up and clear windows etc. A minute or so of idling on a daily basis will eat into milage.
Old Dec 8, 2005 | 11:12 AM
98ISURAM's Avatar
Thanks for the input guys everything you said makes sense, P.J. im thinking about taking the silencer ring out of my turbo as well, did you notice an increase in turbo noise? Im hoping to hear more but was just curious.
Old Dec 8, 2005 | 11:36 AM
Yes... There will be a increase in noise....
If you remove the air tube from the air filter box that goes into the fender it will make it louder.
If you replace the entire air filter box with a BHAF you will really hear it sing...
Then straight pipe it! It will whistle all the time in my case!
Old Dec 8, 2005 | 01:35 PM
98ISURAM's Avatar
MoparMan,
Im still new at the whole CTD scene but what is a BHAF? Some sort of forced air intake? Any power increase noticable w/o the silencer ring?
Old Dec 8, 2005 | 02:27 PM
RowJ's Avatar
BHAF = Big Honkin Air Filter. Do a search...you will see lots of pictures!
No hp increase when removing Ring...just sounds like there is. In some cases removing the ring does reduce turbo "bark". You won't run into that while still stock.
Is your truck a 98 - 12v...or a 98.5 - 24v CTD?
RJ
Old Dec 8, 2005 | 03:21 PM
cditrani's Avatar
Colder air is more dense and requires more power to drive through. This is the #1 reason why highway fuel usage increase in cold weather.
Old Dec 8, 2005 | 05:02 PM
98ISURAM's Avatar
Truck is a 1998.5 24Valve CTD
Old Dec 8, 2005 | 06:18 PM
P.J's Avatar
P.J
They answered your q's, go ahead and lose the ring, it really becomes noticeable when you get rid of the stock airbox.
Mine is on the fringe on being annoying, but not yet
Old Dec 9, 2005 | 06:28 AM
98ISURAM's Avatar
P.J,
Hey you got a nice rig, when you put that 2in leveling kit on did it cause any problems ie. need to buy new shocks or re-align drivetrain etc?
Old Dec 9, 2005 | 06:57 AM
Geico266's Avatar
AND air up your tires!
