wierd code
Old 03-15-2006, 04:51 PM
judge88's Avatar
wierd code
today i got the code P0514 Battery Temperature Sensor Performance / Rationality. anyone know what this means. i was kinda cold here could that be causing it? i cleared it with the bddl and it hasnt come back yet. thanks justin
Old 03-15-2006, 05:18 PM
John Faughn's Avatar
I read were the acid from the batt. can cause problums , get under the wires / connectors and see if there is any carossion is there.
Old 03-15-2006, 05:39 PM
eastmentCTD600's Avatar
The batt temp sensor rationality code has come up many times on many trucks (mine included - used my OBD II reader to clear the code, never came back). I believe there is a fix, replace the sensor. Do a search on that code, someone posted a reason for the code recuring and what the solution was. I don't think its a corrosion issue.
Mexstan
10-22-2004 08:17 AM
Hummin Cummins
18
02-12-2004 03:28 PM
drecu
08-19-2003 12:17 AM
SilverDiesel
06-03-2003 09:39 AM
Quick Reply: wierd code
