which amsoil diff fluid to use
Old 05-04-2007, 01:54 PM
223 rules's Avatar
What would be the best to put in the diffs? The severe gear 75w-110 or the 75w-90? All I ever pull is my bassboat and want the best for mileage. Also how much do I need to order for both diffs? Thanks
Old 05-04-2007, 02:08 PM
MOJO1's Avatar
75-90 is all you need.
Old 05-04-2007, 02:11 PM
PEAKSTRYDE's Avatar
I would suggest REDLINE over amsoil.
I have used a lot of Redline throughout the years, loved it and had much success with it. Haven't used amsoil in anything but a motor, but will NEVER buy anything from the company again!!!
Old 05-04-2007, 03:45 PM
cquestad's Avatar
I am going to try the 115 in the rear to see if I can keep paint on my diff cover!
Old 05-04-2007, 03:57 PM
cquestad's Avatar
Why the Amsoil diss anyways???????
Old 05-04-2007, 04:00 PM
wap
wap's Avatar
Ive got redline 140 in the rearend of my truck and have still lost the paint off of it. Maybe the 115 amsoil will work for ya though.
7qrts should do the job, a little less then for the front and a little less then for the rear, if I remember correctly
Old 05-04-2007, 04:02 PM
cquestad's Avatar
I also changed my paint...to Powder! It better hold. I hate orange pumpkins under my lift!
Old 05-04-2007, 04:44 PM
Nate-03 D's Avatar
You guys are experiencing flaking/peeling of your diff already with 04 & 05 trucks?
My 03 looks great and it should be looking like crap due to all the salt/sand up here in the winter months. You all must tow heavy loads in hot weather then huh?
Old 05-04-2007, 04:52 PM
cquestad's Avatar
It must be the 575 hp going to the ground!
Old 05-04-2007, 04:59 PM
wap
wap's Avatar
Could have something to do with runnin dual 34x12s too or single 37x13s, and towin on top of that.
Old 05-04-2007, 07:58 PM
Snoxracer's Avatar
I'm running the AMSOIL 75w-110 in both front and rear diffs, they say that its best for fuel economy and extreme duty. At the time that I change fluid I also put on Mag-Hytec covers front and rear, and it took all but a 1/4 of a quart out of a case. 11.75 quarts total.
I am running Amsoil in tranny and transfer case and have good luck, since I have change to amsoil I noticed that my tranny temps run cooler on average!
I personally recommend Amsoil, I have used it for years in my race sleds and I have never had a motor failure. Before we ran Amsoil we constantly had exhaust valve problems (sticking) and lost a crank to bearing seizure.
banana
12-01-2009 11:44 PM
ccoop769
08-22-2007 06:09 PM
Kodiakcb
30
04-09-2007 11:14 PM
VikingDiesel
13
04-27-2006 11:24 PM
cummingetit
02-24-2005 10:40 AM
Quick Reply: which amsoil diff fluid to use
