Wheel sticks out
Old Aug 29, 2007 | 12:34 AM
coiler33's Avatar
Wheel sticks out
Just noticed that the drivers side wheel is out further from the wheel well than the passengers side. on the front. Any reason for this.
Old Aug 29, 2007 | 07:59 AM
smokeyram's Avatar
do you have any kind of lift installed? or aftermarket track bar?
once i installed my D 25 coils, pushed driver side out, enough to notice, but not enough to pay for an adjustable track bar.
Old Aug 29, 2007 | 11:29 AM
Pinkston's Avatar
I am guessing the solid steel trac bar you list in your signature is adjustable. You just need to adjust it in a little to center your axle. You will also need to get an alignment done.
Old Aug 29, 2007 | 06:45 PM
fschiola's Avatar
Do you mean the entire wheel sticks out? If so take off the wheel and see if a spacer is between the wheel and the rotor. If their is, remove it and put it behind the right front wheel. The spacer was an attempt by the factory to stop a pulling condition and it sometimes sticks to the wheel during a tire rotation.
joelmopar12
Mar 15, 2006 10:38 PM
turfquip
Dec 13, 2003 10:53 PM
Garz
Feb 18, 2003 10:07 PM
TIM-D-FARMER
Jan 6, 2003 08:32 PM
